Results 1 to 6 of 6
    Full Member level 4
    Points: 1,238, Level: 7
    Jan 2018
    202
    1,238
    7
    What is the difference between BVDSS and BVDS
    Hi, Which is Drain to source breakdown voltage and substrate breakdown voltage. Can you aslo elaborate what they are exactly.
    Points: 260,253, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,447
    260,253
    100
    Re: What is the difference between BVDSS and BVDS
    You're surely asking about the model parameter syntax of a specific tool. What is it?
    Full Member level 4
    Jan 2018
    202
    1,238
    7
    I know, in general, BVDS means drain to source breakdown voltage and I wanted to know how substrate breakdown voltage is represented. While I was in search of that I came across BVDSS, which I don't know about.
    Points: 14,971, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,488
    14,971
    29
    The last letter of Semiconductor syntax indicates the condition of the third terminal. Which in this case is the gate and is Shorted
    My batteries are recharged by "Helpful Post" ratings.
    Full Member level 4
    Jan 2018
    202
    1,238
    7
    Quote Originally Posted by schmitt trigger View Post
    Thanks. How is substrate breakdown voltage is denoted, any short form? I am looking for its value in the PDK but I find it nowhere.
    Points: 39,762, Level: 48
    Mar 2008
    USA
    6,426
    39,762
    48
    That would be something like BVdb_ but this is often not
    specified separately (especially if the foundry knows that
    lateral punchthrough or hot carrier reliability degradation
    happens well below D-B breakdown, which would be a
    normal device-design-to expectation (why would you let
    the isolation junction be the weak link in process construction?).
