Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Junior Member level 1
    Points: 102, Level: 1
    Sep 2019
    17
    102
    Re: Flyback SMPS power MOSFET getting hot? uc3843 pwm converter
    the power mosfet don't have any RC snubber circuit. is it necessary in a flyback smps with power mosfet?
    the xformer have an RCD snubber with R = 47K/2W, C = 103pf & fast recovery diode FR107.
  2. #22
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    RCD snubber is the appropriate method to absorb primary overvoltage caused by transformer leakage inductance. You have to check the actual primary voltage and current waveforms, an additional RC snubber will unlikely improve anything.
    The transformer air gap should be sufficient to avoid transformer saturation. If Bmax is actually 260 mT, transformer core will run very hot, but not cause problems for the transistor.
    Are you sure that the converter is operating regularly with constant duty cycle? Hard to determine without oscilloscope measurement.
  3. #23
    Points: 11,046, Level: 25
    Aug 2015
    1,788
    11,046
    25
    rcd snubber usually across transformer primary ...
  4. #24
    Sep 2019
    17
    102
    this protective turn off RC snubber? is it necessary with power FET?
    the xformer have RCD snubber with R = 47k/2w, C = 103pf/1kv & fast recovery diode FR107.
    surprised with the chinese smps PQ3230 xformer of this circuit. where the Nprim = 40T (swg25 x 3). and using the same air gap of about 0.9mm.
    how its possible? i tried my own xformer also with external 12v-1amp power supply but still mosfet heating.
    if the cause of this problem is the core being going into saturation how can i check this?
  5. #25
    Aug 2015
    1,788
    11,046
    25
    you need to learn about leakage inductance - also as we cannot see you gate drive - this may be a problem too ...
  6. #26
    Sep 2019
    17
    102
    for the time being the problem of power FET heating solved by adding a turn off RC snubber across FET.
    the power FET now heat up normally with load.
