Results 1 to 17 of 17
    Points: 522, Level: 4
    Oct 2017
    33
    522
    Looking for a suitable DC -DC buck conveter topology
    Hello there,
    Anser this post who knows Power Electronics well.
    Take a look my buck conveter in attachment.
    People may called it "Dropper'
    It has following properties,
    1. Input is 120 to 160 volt DC/ 30 Amp.
    2. Output must be 110volt/30 amp(maximum). +- 5% regulation( contineous output should be 20 amps)
    3. Isolated in both input and output circuit.
    4. Shunt sensing.
    5. proper feedback.
    6. 2 switches gets OFF/ON alternately.
    7. May be soft switching.
    8. May be 90% efficient.
    I am thinking to modify it because bulky reactor/coupled inductor.
    It has high current application.
    kindly suggest a design that has
    1. Less switching losss.
    2. Less stress on switch.
    3. Less number of component.
    4. ZVS or ZCS idea.
    5. Suitable ripple minimization.
    6. Suitable couple inductor design.
    Hasan
    Points: 11,046, Level: 25
    Aug 2015
    1,788
    11,046
    25
    Re: Looking for a suitable DC -DC buck conveter topology
    you are missing the diodes on the LH side for a buck converter ( interleaved )
    with the diodes added the ckt will work OK and meet your specs - will need caps on the i/p too
    you cannot couple the L's in this ckt
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    Coupled inductors have repeatedly suggested in literature for interleaved buck converters, see e.g. https://www.researchgate.net/publica...rter_POSTPRINT
    In the general case, coupling factors of 0.6 to 0.7 are implemented.
    As for the other points, there's no simple way to implement soft switching in this topology.
    Aug 2015
    1,788
    11,046
    25
    I have yet to see one that works very well, or has the same self shielding as, say, 2 x RM14 cores ... a lot of these papers never consider EMC aspects ...
    Oct 2017
    33
    522
    Nice to get your feedback.
    Can not we raise " Phase" in DC-DC buck action.
    Because of 2 switch? Multiphase but not interleaing?
    Looking at this circuit it seems like a 2 conventional buck converter working at a time or alternately ! Need to analyze both DCM and CCM mode for the inductor. If its not coupled inductor that means 2 inductors are not magnitically coupled!
    Can you see any " transformer" action on it?
    As its output and input currents are same, then yes ! Voltage should be control.
    Interesting to see its ON and OFF circuit. What would be the charging and discharging path in this circuit?No freewhiling action? 2 capacitors are helping charging or discharging through to load?
    Input power isolation has done with some transformer and optocoupler.
    Output can monitor by shunt sensing.
    Couple inductor is more cost effective but high current and voltage need to be carefully solve. High current IGBT is only solution?
    For HVDC application people use many IGBT in sequence !
    Hasan
    Full Member level 6
    Points: 2,003, Level: 10
    Jan 2019
    373
    2,003
    10
    I suggest putting the voltage detect on the output side of the shunt (right side in your picture) instead of the
    regulator side (left) as you want the output voltage, to be correct, not a little low
    I suggest the current shunt resistor be in the low side (-), instead of the high side (+)
  7. #7
    Points: 14,929, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,482
    14,929
    29
    In your properties list, you include the following:
    This means a transformer requires to be used.
    Transformer switchmode topologies include push-pull, half bridge, and full bridge.
    Either ZVS or a ZCS are suggested for the higher power bridge topologies, but they are technically challenging.
    I will give you the best advice: Search the TI website for full bridge controllers. Study some of the datasheets and app notes. Using paper and pencil, or an Excell spreadsheet, go thru all the design equations and solve all the variables and select appropriate components. Simulate a circuit or two.
    And you have not even touched thermal management, EMI concerns, board layout with safety issues in mind, protections and monitoring.
    I am not attempting to scare or dissuade you. But you must be aware of the significant technical challenges, and determine whether this is a project you can actually complete succesfully.
    My batteries are recharged by "Helpful Post" ratings.
  8. #8
    Aug 2015
    1,788
    11,046
    25
    Well spotted Mr Schmitt trigger, the OP does call for fully isolated apparently, so yes, push pull, half or full bridge are good options ...
    with suitable transformer, Hasan, we have a standard card that would do that ... per pic Click image for larger version.
Name:	Series 3000 DC-DC.jpg
  9. #9
    Oct 2017
    33
    522
    Hello Sir schmitt trigger !
    I found you always helpful.
    Yeap, little study is necessary.
    Tnasformer is must may be !
    Hasan
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    I ignored the "isolation" point in post #1, because it makes no sense related to the diagram. If isolation is required, "Isolated in both input and output circuit" makes still no sense. There can be isolation between input and output, but what does "both" mean. Possible isolation of control circuit and e.g. gate driver is a different topic and not directly related to power circuit isolation.
  11. #11
    Oct 2017
    33
    522
    Mr. FvM,
    Take a look on this transformer ,
    Could you guess something ?
    For your full understanding, isolation means output and input can work without effecting each other.
    The people who read "Power Converter" can easily recognize what I am saying, even I did wrong in post.
    Quote Originally Posted by schmitt trigger View Post
    Depending on power density and application, I want to change this converter.
    Looking for a solid usable topology.
    I think this basic diagram is confusing!
    Its an old design.
    Hall effect IGBT sensor might cause some problem in sensing. OP- AMPs are back dated, so may be malfunction occurs.
    I will let you know what actual problem exists in this design.
    I
    Hasan
  12. #12
    Aug 2015
    1,788
    11,046
    25
    From your transformer diagram - you have a pri wdg and a sec wdg ( centre tap ) for the power transfer and then an auxilliary wdg on each side too - for local control power ...
  13. #13
    Oct 2017
    33
    522
    Yeap!
    Well said.
    Now depending on the winding/ turns cant you tell what what would be the converter type?
    Hasan
  14. #14
    Aug 2015
    1,788
    11,046
    25
    that transformer is not good for much ...
  15. #15
    Oct 2017
    33
    522
    I do appreciate your analysis and effort you did here!
    Yeap! This circuit is nonsense indeed.
    Because of ...
    1. No freewhiling path/ diodes.
    2. Energy storing device alignment is wrong for sure.
    3. Inductors are parallel, means it fails to describe wheather its bridge type or flyback type.
    4. In this application, user must think a power transformer with center tap winding in sencondary!
    5. CCM or DCM mode circuits cant be explain, because stupid circuit path.
    Lets move our mind from this design to this follwing one ( its from a knowledgeable researcher)
    Can you feel anything clear from it?
    1. Input coupled inductor maintains isolation?
    2. For the ON/ OFF of switch( Mosfet/ igbt/)
    , free whiling paths is notiable.
    3 . More simple that might not require ZVS, ZCS.
    4. Gain equitation can be possible to find.
    5. Interesting to see how the parallel capacitor shows the advantage.
    6. For this kind of high current application, not sure the switch would be long lasting or the inductor size!
    What do you think sir?
    Hasan
  16. #16
    Aug 2015
    1,788
    11,046
    25
    it is not isolated ....
  17. #17
    Oct 2017
    33
    522
    In sense of input and output its true, but clarify it from your mind!
    Hasan
