ERROR:HDLParsers:709
abimann
Member level 4
Dear all Gurus and just good guys!
Pls tell me what's wrong with my code, top level file is in VHDL , lower level file is Verilog,why i get this kind of error ?
I remember that VHDL and Verilog works well in my old projects and this is not reason.
ERROR:HDLParsers:709 - "C:/Users/user1/Desktop/fpga_p/MT9/camera_v0.vhd" Line 229. Reset_Delay is not an entity name
signal DLY_RST_1, DLY_RST_0,DLY_RST_2:  std_logic;
U1:  entity work.Reset_Delay
 PORT MAP( iCLK       => clk96,
		  iRST       => rst_n,
		  oRST_0     => DLY_RST_0,
		  oRST_1     => DLY_RST_1,
	          oRST_2     => DLY_RST_2 );
module	Reset_Delay(iCLK,iRST,oRST_0,oRST_1,oRST_2);
input		iCLK;
input		iRST;
output reg	oRST_0;
output reg	oRST_1;
output reg	oRST_2;
Try to declare the component prototype of "Reset_Delay" in the .VHD file where you instantiate it - instead of instantiating it from work.reset_delay.
VHDL has no knowledge of Verilog. Hence directly accessing a Verilog module from a vhdl library is illegal because it doesnt exist.
You need to use a component to give the VHDL compiler knowledge of what the entity is, then let the tool map that component to a Verilog module.
