Results 1 to 6 of 6
    Full Member level 4
    Points: 1,327, Level: 8
    Jan 2018
    220
    1,327
    8
    How to realize inductor from transmission line (micro-strip and CPW lines)
    Hi, I am reading the paper "Broadband Impedance Matching Network for RF Power Amplifiers" and came across idea of realizing Inductor using microstrio line.
Name:	inductor from transmission line.JPG
    (1)As per the above formula, I can find what is the required length of the line for that particular inductor value. Anyone knows the same kind of formula for CPW line? And how do I know what should be the charateristic impedanced of the line, are there any conditions or procedures to choose it?.
    (2)But as per below formulas also we can get inductance.
    I know that (2) can be used while doing stub matching but we can also use (1) for matching, however it is just the substitutuon of inductor. I want to know which one to use when and any more insight on this. Thanks.
    Points: 17,492, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,689
    17,492
    32
    Re: How to realize inductor from transmission line (micro-strip and CPW lines)
    Quote Originally Posted by circuitslave View Post
    Anyone knows the same kind of formula for CPW ]line?
    It is same.
    Use transimission line calculator which supports CPW.
    They are all same.
    Learn and understand very basic things surely.
    Consider how to realize short.
    Simply if it is difficult to realize short, short stub is not chosen.
    If you use laser trimming, you have no option except for open stub.
    Learn actual measurement not EDA Tool Play.
    Points: 30,904, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,538
    30,904
    42
    CPW cannot be used for Inductor Realizations.Especially if the frequency is not sufficiently high, making an inductor by using Transmission Lines is not practical at all..
    Oct 2006
    Real Homeless
    2,689
    17,492
    32
    Quote Originally Posted by BigBoss View Post
    Short circuit CPW is used as matching stub, where impedance could be inductive.
    Points: 34,266, Level: 45
    Oct 2001
    4,894
    34,266
    45
    The simplest microstrip inductor would be from a microstrip line without ground (the ground decrease somehow its inductance).
    The inductance of an isolated (no groundplane), high impedance microstrip line (W << W(Zo)) is given approximately by:
    L(nH/mm) = 0.2*{ln[l/(W+t)]+1.193+0.2235(W+t)/l}
    where W is the width of the strip line, t is the metal thickness, and l is length.
    Full Member level 4
    Points: 1,516, Level: 8
    Jan 2019
    Ireland
    208
    1,516
    8
    CPW stands for co-planar waveguides. Transmission lines can be realized on-chip using co-planar metals as Ground-Signal-Ground configuration. It can also be realized by routing the signal trace on a different metal layer and ground on a different metal layer. Then its no longer CPW.
    How to choose Z0?
    Increasing Zo will mean that you get the same inductance for a shorter length of line --> lesser losses. Also, the bandwidth of matching using transmission lines increases when the impedance to be matched and the characteristic impedance are close to each other. Its an iterative process to get it right.
    I also hope you realize that the first expression comes directly from the algebraic manipulation of a shorted stub.
