Results 1 to 5 of 5
    Junior Member level 1
    Points: 335, Level: 3
    May 2018
    17
    335
    DC-DC converter to -3.3v
    I need a DC-DC converter with a positive voltage input (+5V) and a negative voltage output (-3.3v) with a current minimum of 2A.
    Can suggest me a circuit or a low cost Converter on a supplier or on ebay?
    Points: 260,240, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,443
    260,240
    100
    Re: DC-DC converter to -3.3v
    One possible solution is buck converter in inverting configuration, see e.g. http://www.ti.com/lit/an/snva022e/snva022e.pdf
    Advanced Member level 2
    Points: 2,906, Level: 12
    Aug 2016
    509
    2,906
    12
    Quote Originally Posted by clros View Post
    You need an inverting buck-boost. You could design it for 2.5V to 5V input range or so and -3.3V output.
    That's all.
    --Akanimo.
    Points: 77,827, Level: 68
    Apr 2014
    15,771
    77,827
    68
    Or use a ready to buy isolating one. 5V to 3.3V.
    Points: 52,941, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,948
    52,941
    56
    Charge pump configured to invert polarity. Notice your 5V supply must provide several Amperes, if you wish to attach a 2A load.
Name:	negative supply -3_5V fm 5V via charge pump 4 transistors load 2A.png
    Although diodes make for easier construction, they subtract from the output voltage. Instead transistors are suitable. Bias signals can be obtained from strategic points in the circuit.
    The transistor marked '?' carries 90mA in an upward direction when it's supposed to be off. I tried to shut it off by taking bias voltage from various points. I tried a PNP type. It appears the only way to shut it off is by building a second clock signal.
