Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 45
    Advanced Member level 2
    Points: 2,224, Level: 10
    Aug 2016
    578
    2,224
    10
    Inductor quality value for switching regulators
    Does an inductors quality value also mean its ferrite material will have minimal losses at the frequency at which it has highest quality value?
    Points: 11,163, Level: 25
    Aug 2015
    1,814
    11,163
    25
    Re: Inductor quality value for switching regulators
    depends on the freq at which the Q is measured, QL can be expressed as wL/R ( w = 2.pi.f ) if the Q is given for a range of chokes at the same freq then you can compare meaningfully - highest Q will give the lowest loss as long as you stay well away from saturating the ferrite, i.e. < B = 40mT at 1200kHz
    Full Member level 6
    Points: 3,609, Level: 14
    Sep 2013
    395
    3,609
    14
    Well the Q value is the ration between reactance to the resistance of the coil, both having unit in Ohm so Q value is unit less.
    We can’t directly link Q value to the core losses but indirectly linked.
    Suppose identical construction (same core material and conductor) of two toroid inductor having same Q value, if we change the core material of one inductor with very low core loss material then Q value of that inductor will increase because low core loss material get higher inductance or reactance
    Points: 77,800, Level: 68
    Apr 2014
    15,765
    77,800
    68
    I can't remember to ever have seen a "Q" specification in a "storage" inductor for swiching regulators.
    But maybe there are.
    In my eyes it makes not much sense, because "Q" is usually given for a DC free, sinusoidal waveform.
    Typicall for HF filter inductors.
    Aug 2015
    1,814
    11,163
    25
    any switching regulator that uses a choke has an element of AC or ripple current in it - at high freq's Rac and core losses can often dominate over the "DC" losses in the winding. As B is directly proportional to current I, flux swing is directly proportional to I swing ...
    Aug 2016
    578
    2,224
    10
    What are these curve depicting? https://www.digikey.com/product-deta...2-1-ND/5880186
    It seems somewhat related to Q and impedance.
  7. #7
    Aug 2015
    1,814
    11,163
    25
    they actually show impedance ZL with freq - not true inductance where it curves up ...
    true Q curves with freq are very rare these days - as it shows quite clearly how shite most off the shelf chokes are
  8. #8
    Aug 2016
    578
    2,224
    10
    Perhaps the manufacturers dont prefer to maintain costly measurement equipment which must be calibrated regularly which must measure a certain quantity from each batch for it to provide some accuracy to the datasheet for a product line. It might be a mechanism to liquidate bad batches if their QC isn't performing well.
    Is that 221M inductor compatible with 1.2Mhz? It appears to land right as the curve initiates to increase.
  9. #9
    Aug 2015
    1,814
    11,163
    25
    You can't tell anything about the losses from those curves
    Q is easy to measure, and even +/- 5% Q curves would be of value to a designer - but the cheaper offerings have cheap ( read lossy ) ferrites and the real Q is low
    Q curves over freq and over various DC bias - would tell you everything about a choke - this is why they don't do it any more .... the first to do it would look bad ...
  10. #10
    Aug 2016
    578
    2,224
    10
    Much akin to lambda power supplies in which among other things TDK capacitors are utilized. Also TDK is a well known supplier of a vast variety of ferrites. They appear to have much works with ferrite materials which might cause them to use the better type in their less expensive inductors.
    Does a high SRF (higher than intended switching frequency) determine whether a core material is decent?
  11. #11
    Aug 2015
    1,814
    11,163
    25
    No ... not in the slightest ...
    the SRF must be much higher than Fsw by the way ...
  12. #12
    Aug 2016
    578
    2,224
    10
    Is the SRF more likely to give issues to a switching regulator than a lossy core material?
    Perhaps a lossy material is fine to use if its not saturated to high losses causing excess heat to the regulator.
  13. #13
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    "more likely" is the wrong question. Both parameters are linked to different circuit issues. Core losses are causing core heating, winding capacitance as manifested in self resonance frequency causes EMI problems and possibly excessive switching losses.
    Regarding Q curves, there are applications beyond storage inductor, e.g. filter where Q may be of interest. As this are small signal values, they don't tell anything about storage inductor losses.
  14. #14
    Aug 2015
    1,814
    11,163
    25
    I have to disagree with FvM, Q measurement applies to power and storage i.e. buck inductors too, a high Q, even at signal level, indicates a low loss construction,
    of course Q can be measured at any power level, but if you measure two chokes of the same uH on a proper Q meter, the higher Q one will have the lower losses in a power circuit.
  15. #15
    Aug 2016
    578
    2,224
    10
    Is a 1000uH inductor with Q (from datasheet) of 40 measured at 0.796Mhz very lossy for 1200Khz operation?
  16. #16
    Points: 17,232, Level: 31
    Nov 2012
    3,148
    17,232
    31
    You are right.
    An inductor does not have a Q value because it has only one definite parameter: L (inductance).
    An ideal inductor is free from resistance or capacitance. It does not have a time constant or associated Q value.
    We can define a time constant if the inductor is coupled with a capacitor or a resistor. An ideal LC pair has a very high Q because there is no dissipation. The absorption spectrum of a LC circuit is a simple vertical line.
    If the inductor is coupled with a resistor, the Q is low, because of losses and the absorption spectrum will have a broad peak.
    Q of an inductor does not make any sense whatsoever.
    of course Q can be measured at any power level...
    I am not sure I understand that...
    Q is a measure of the quality of the absorption band; narrow bands have higher Q.
    The absorption is measured by scanning a frequency and measuring the power absorbed by the sample circuit. You get a graph of absorbance vs frequency. The absorbance is dimensionless (log scale, e.g., db is common) and used on the Y axis.
    The excitation power must be as small as possible to reduce saturation. Q has no meaning if you are using high excitation power.
  17. #17
    Points: 2,884, Level: 12
    Aug 2016
    509
    2,884
    12
    Quote Originally Posted by Zak28 View Post
    We cannot conclude on this just like that. It would depend more on what the dominant losses are for the inductor. Sometime eddy current and proximity losses dominate but they are not necessarily core losses.
    Overall, it can be concluded that the total losses is least at that frequency relative to the inductive reactance. However, to conclude on core loss behavior specifically, a little bit of analysis has to be done that would have to account also for other losses like eddy current and proximity.
    --Akanimo.
  18. #18
    Aug 2015
    1,814
    11,163
    25
    A Q of 40 at 800kHz, D = dissipation factor = 1 / Q
    (the fundamental definition of Q = 2.pi * peak energy stored / energy dissipated per cycle )
    For a cap dissipation = Vac(rms) x Iac (rms) * D = power dissipated
    And I assume the same is true for an inductor
    So for Q = 40, D = 1/40, this implies if the was an ac voltage across the L of 1V rms say and 300mA rms @ 800kHz, the power dissipated would be 0.3/40 = 7.5mW
    However in a ferrite core, losses are proportional to around Bpk^1.7 & Freq^2 so as excitation goes up ( current swing or flux swing ) the losses go up more than proportionally
    so the Q would need to be measured at or near a typical operating point - this can in fact be done in a resonance tester with sufficient driving power ( to supply the losses ) as the bulk of the current simply swings back and forward between the cap and the L it is in parallel with ...
  19. #19
    Aug 2016
    578
    2,224
    10
    Can core losses be mitigated for 1200khz by avoiding shielded or partially shielded inductors and use higher resistance parts instead to avoid core losses, or does winding resistance incur greater losses?
    Perhaps there is an inductor build type which is overall better with high frequencies, the unshielded bobbin types appear to be with greatest winding resistances.
  20. #20
    Apr 2014
    15,765
    77,800
    68
    You defined the current with "800kHz 300mA RMS"
    And you think this is true for
    * DC free sinusoidal waveform 800kHz 300mA RMS?
    * 0A / 1A square wave with 9% duty cycle, which also is 800kHz, 300mA RMS?
    * or a 0.105A / 0.9A square wave with 9% duty cycle, which also is 800kHz, 300mA RMS?
    * Or the more triangle shaped current waveforms in CCM, ... with 800kHz, 300mA RMS?
    * Or the more triangle shaped with variable long 0A sections current waveforms in DCM, .... 800kHz, 300mA RMS?
    I don't expect it.
