Results 1 to 3 of 3
    Points: 565, Level: 5
    Nov 2016
    9
    565
    TMS320F280049C: Unwanted pulse on GPIO during Power On/OFF
    I'm using TMS320F280049C micro-controller (Texas).
    While testing its GPIO behavior during power on/off, I found a high to low transition on GPIO pin ,on every power on/off
    I'm checking the waveform on GPIO pin of micro-controller itself.
    I have used the same code provided by texas for GPIO initialization (C2000 examples)
    //Initialization code as follows:-
    GpioCtrlRegs.GPAPUD.bit.GPIO3 = 0; //Enable pull-up on GPIO3
    GpioDataRegs.GPASET.bit.GPIO3 = 1; //Load output Latch
    GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0; //GPIO3= GPIO3
    GpioCtrlRegs.GPADIR.bit.GPIO3 = 1; //GPIO3=output
    Attatchment:- Waveform during Power On/off.Click image for larger version.
ID:	155238Click image for larger version.
    Points: 24,271, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,655
    24,271
    37
    Re: TMS320F280049C: Unwanted pulse on GPIO during Power On/OFF
    What you're seeing is perhaps due to the output going tri-state. Do you see this behavior on every pin? If not, what is different about what is connected to this pin? Is there a capacitance? Maybe you need a pull-down resistor on the pin.
    Points: 77,800, Level: 68
    Apr 2014
    15,764
    77,800
    68
    What is connected to the pin?
    As a general recommendation: don't leave it floating. You can't expect any level from a floating signal, because it is not defined.
    And, because a floating signal is high impedance it can be influenced from any signal nearby.
    Maybe you just see coupling effects from another signal.
