Results 1 to 6 of 6
    Junior Member level 2
    Points: 196, Level: 2
    May 2019
    22
    196
    Circular polarization using coupler
    hello,
    i'm designing a patch antenna in hfss. in order to achieve circular polarization i'm planning to use a 90 degree hybrid coupler. Is it possible to create a 90 degree phase shift in orthogonal mode excitation in hfss without actually having to draw a coupler. thanks in advance.
    Points: 6,806, Level: 19
    Jun 2012
    Edmonton, Canada
    1,044
    6,806
    19
    Re: Circular polarization using coupler
    Hi gayathrim,
    Yes, it is possible. Using either lumped ports or wave ports, you can set the sources excitation phase under "HFSS"->"Fields"->"Edit Sources...".
    Good luck!
    May 2019
    22
    196
    I tried that. I used two lump ports positioned 90 degrees apart and sources changed to phase 0 and 90 respectively. however, i'm still not able to achieve an axial ratio vs frequency below 3 dB for resonating frequencies.
    Jun 2012
    Edmonton, Canada
    1,044
    6,806
    19
    Quote Originally Posted by gayathrim View Post
    Unfortunately, the issue is then your antenna, and not the excitation. Is it a circular patch?
    May 2019
    22
    196
    Quote Originally Posted by PlanarMetamaterials View Post
    yes, it is. and the axial ratio at non resonating frequencies are less that 3 dB. but at resonating points, greater that 15dB.
    May 2019
    22
    196
    Also, since there are two ports, which return loss should we consider? s11 or s22? or the resultant?
