Power limitation using ic power integration topswitch
hichamcentre
Junior Member level 1
hi every body,
So i find this circuit (flyback power supply 24 V 1 A) which use the ic top255yn from top-switch HX and the transformer MYRRA 74030 so i would to change it with the ic top245yn from top-switch GX,i know for that i need to change R3,R4 and R5 (R6 and R7 i know how to change them) so how i can calculate the values of R3,R4 and R5 to get the same features (Vout,Iout,Pmax).
Cordially.
either read the datasheet , do ctrl F search, or do a design in PI Expert from Power integrations.
If you post the datasheet link i will help you search.
Suggest you upgrade the bridge rectifiers to 1N4007. With 265V AC at the input they only have 50V PIV rating overhead and could easily be damaged by relatively small transients on the AC.
thanks for your note, but i think its ok because the reverse voltage of 1N4006 is 800 V
