Results 1 to 4 of 4
    Points: 965, Level: 7
    Jan 2016
    43
    965
    7
    Magnitude function analog circuit (square root of sum of two squares)
    I have output of quadrature mixer and I need it's magnitude for current application. I want to build a circuit that does A = sqrt(I^2+Q^2), and it should also have duty cycle of 10%, so it should be triggered by that function.
    Can someone point me to a resource (website, book, journal, etc.) that explains how to build it?
    Advanced Member level 3
    Points: 5,238, Level: 17
    Nov 2013
    766
    5,238
    17
    Re: Magnitude function analog circuit (square root of sum of two squares)
    Not enough to multiply the I branch with the Q branch signal? The multiplied output's DC level should be rational with the I and Q magnitudes. RSSI operates this way usually.
    Tell us more about the application, the operating frequency, and explain this please: "have duty cycle of 10%, so it should be triggered by that function" I don't get it what you mean on.
    "Try SCE to AUX." /John Aaron/
    Jan 2016
    43
    965
    7
    Quote Originally Posted by frankrose View Post
    By 10% duty cycle I mean that the my I&Q signals are on for 10% of the time. I'll see what happens when I multiply I by Q.
    Points: 265,270, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,351
    265,270
    100
    In case of doubt, you'll implement the analog function blocks according to the given formula: squarer, sum, square root. In case you use single quadrant multiplier, absolute value will precede the squarer.
