Results 1 to 5 of 5
    Newbie level 3
    Points: 34, Level: 1
    Aug 2019
    34
    Introductory literature on PLD
    Hi everyone!
    I'm about to start learning PLD. What book (or books) which would be a good introduction could you advice?
    Points: 31,335, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,235
    31,335
    43
    Re: Introductory literature on PLD
    Quote Originally Posted by MikhailFrolov View Post
    Hi everyone!
    Actual PLDs? e.g. 22V10, 16L8, etc?
    or are you learning about something more modern and in current use and just referring to a programmable device as a "PLD".
    PLDs still exist but aren't used that much anymore. AFAIK there aren't any books on simple PLDs like 22V10s. The datasheet will tell you everything you need to know.
    Newbie level 3
    Aug 2019
    34
    I have Intel FPGA MAX10 – that is what I am planning to work with.
    Full Member level 6
    Points: 1,920, Level: 10
    Jan 2019
    360
    1,920
    10
    good start
    read the data sheet
    get a development board and download the software
    go through the examples
    when you run into a problem,
    show the work you did, what the computer told you,
    and ask specific questions
    ads-ee's Avatar
    Sep 2013
    USA
    7,235
    31,335
    43
    So a CPLD, which is much larger than a PLD. You'll probably want to do as wwfeldman posted and read the data sheet, but you'll probably also want to get a book or read an online tutorial on VHDL or Verilog/Systemverilog as a way to write the hardware description of your design. I doubt you want to use some ABEL variant as that is basically a dead end in usefulness.
