Results 1 to 2 of 2
    Advanced Member level 3
    Points: 5,282, Level: 17
    Jan 2012
    Italy
    919
    5,282
    17
    Running the digital simulation irun or xrun in Cadence
    Dear Friends,
    I need to learn how to run the digital simulation "irun" or "xrun". I need this simulation to run some of verlig code and then to save the output in VCD form which I will use it in other simulation.
    I tried to type irun in the command window but seems it is not the correct way.
    Thank you in advance for your help
    Best Regards
    Points: 16,713, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,570
    16,713
    31
    Re: Running the digital simulation irun or xrun in Cadence
    What do you mean by "in Cadence" ?
    You visited Cadence Office ?
    Use correct terminology ?
    If you mean Cadence NCSim or Incisive, do you surely insert system tasks for dumping VCD ?
    $dumpfile("waves.vcd");
    $dumpvars(0, test);
    The followings don't generate VCD.
    $shm_open("waves.shm");
    $shm_probe("AS");
