Results 1 to 6 of 6
    Points: 2,423, Level: 11
    Sep 2007
    40
    2,423
    11
    How to measure differential signals using an Oscilloscope
    Differential signal measurement in practice
    To measure a differential signal, we have two options, one is using a differential probe and second is using a two channels oscilloscope. A differential probe is expensive but handles a better accuracy. Using two/four channels oscilloscope is the cheapest method which handles acceptable results.
    Just you need to connect oscilloscope’s Channel-1 to one of the differential lines/wires and Channel-2 to another one. Then go to the math function and enable CH1-CH2 which means a difference. Then adjust the oscilloscope to observe the signal. You use the run/stop or a single shot button to freeze the signal on the screen and examine it.
    I have examined the ADSL2+ signal on the telephone line using the above-mentioned differential measurement method.
    Reference: http://bit.ly/2Z7sDTt
    Points: 30,243, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,422
    30,243
    42
    Re: How to measure differential signals using an Oscilloscope
    This method is a bit subjective and unstable.If the frequency is sufficiently high, phase shifts will be different by oscilloscope channels so the measurement may be a bit erroneous.
    You presume that the oscilloscope has %100 identical channels and Phase Shifts are linear but this is not true in reality..
    Sep 2007
    40
    2,423
    11
    Quote Originally Posted by BigBoss View Post
    I am agree, as I mentioned in the article using the differential probe is the best, but not necessarily high voltage differential probes, because the main problem is to deal with high frequency pulses. This method at least gives a close picture of the final signal. The result on the screen is the result of the difference
    Points: 14,815, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,462
    14,815
    29
    Also....one has to make sure that both probes are properly and equally compensated.
    A good way I have found is to compensate each probe individually (with the scope's CAL SIGNAL output).
    Then attach both probes simultaneously to the same CAL output and perform the A-B comparison, and slightly tweak for maximum cancellation.
    My batteries are recharged by "Helpful Post" ratings.
    Points: 39,524, Level: 48
    Mar 2008
    USA
    6,386
    39,524
    48
    Quote Originally Posted by schmitt trigger View Post
    I like to use the "signal of interest" (or one side of the pair)
    for this because the CAL signal on most 'scopes is way lower
    frequency / edge rate than most of what I look at.
    You would of course like to get identical model# probes to
    start with.
    Advanced Member level 2
    Points: 3,716, Level: 14
    May 2012
    500
    3,716
    14
    On older oscilloscopes you invert one channel and sum the two channels. One problem with doing this is that the bandwidth is drastically reduced to around 1Mhz depending on the scope.
