Please can you explain me this font 8X8 row and col adress
michael 1978
hi
can somebody explain me, how does work this
[5:0] char_row = row_addr[8:3];
[2:0] font_row = row_addr[2:0]; //char row 8x8
[6:0] char_col = col_addr[9:3];
[2:0] font_col = col_addr[2:0]; // char col 8x8
this 8X8 font but the address [8:3] for row and adress for col [9:3], what does do this bit 4 in row and column
thnx
Re: please can you explain me this font 8X8 row and col adress
hi
thnx
You are not mention the surrounding circuit so it's a bit hard do know what you want to obtain, but try to have a look here this is a good explanation of how a font are used for VGA
https://www.fpga4fun.com/GraphicLCDpanel4.html
hello
i just dont understand the
wire [3:0] LCDdata = CounterX[0] ? raster8[7:4] : raster8[3:0]; raster8[7:4] the bit 4(5) is the ram character?
hello
This is a mux with the lower bit of CounterX being the select which is what the text above it describes
ecause my LCD panel takes 4-pixels per clock, we need 2 clocks for 1 character width (1 character width=8 pixels). That's why "Character RAM" uses "CounterX[6:1]" instead of "CounterX[5:0]" above.
So for 8-pixels you need 2 clocks. I'm assuming the raster8 contains the pixels and the LCD takes 4-bit data, so hence the mux. Selecting between the raster[7:4] and then raster8[3:0].
You will need to tell the FONT look-up ROM what character to show eg A,B,C....(ASCII) and what Row (Line) and Column(Pixel)
To make it a bit more easy to use you will typical write your text to a RAM with the message to show like (Hello World)
So you will also need to tell the RAM what output position you message you want to send to your FONT ROM
There are many FPGA VGA examples on the web like here:
https://opencores.org/projects?expanded=Video%20controller
thank you man for time....i think i understand:thumbsup:
thanks....
thnx to everyone for help
greetings..
