Results 1 to 9 of 9
    Junior Member level 1
    Points: 116, Level: 1
    Jul 2019
    18
    116
    Transferring data from PS to PL
    Hello, I have created my own IP in Vivado which takes some data from a sensor using I2C protocol and stores them in the memory mapped registers in the processing system (PS) through SPI protocol.
    What I would like to do now is to send the data from the PS to the FPGA (PL, programmable logic). I have checked on internet and I found I have to use the AXI interface, but most posts were about transferring data from PL to PS. Can someone give me some references to send data from PS to PL, please? Thanks!
    Points: 259,331, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,280
    259,331
    100
    Re: Transferring data from PS to PL
    What is PL and PS?
    See forum rules, you shouldn't use
    Technical abbreviations unless they are universally understood, they will confuse members and make it hard for them to understand what you mean.
    Jul 2019
    18
    116
    I'm sorry, I have edited the post.
    Points: 6,208, Level: 18
    Feb 2015
    1,020
    6,208
    18
    IIRC PS-PL is mainly for control/status -- lower rate stuff. I think the normal flow is for the PL to take general commands from the PS, provide updates to the PS, and sometimes access PS memory.
    Points: 8,501, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,272
    8,501
    22
    Blog Entries
    For PL to PS, you can also use the AXI i/f.
    The PS section can typically stay as the master and the PL section can stay as the AXI slave.
    The AXI master side (PS) needs to initiate a write transaction to the slave (PL).
    FPGA enthusiast!
    Jul 2019
    18
    116
    Thank you for your replay! I'm sorry but I'm new with SDK. I know I should write some code to write something in the PL. Since I just need to store a value from the PS to the PL, I was reading I can use "Xil_io" library. Do you think is this a right way to proceed?
  7. #7
    dpaul's Avatar
    Jan 2008
    Germany
    1,272
    8,501
    22
    Blog Entries
    FPGA enthusiast!
  8. #8
    Jul 2019
    18
    116
    I already went through these links, but thanks!
  9. #9
    dpaul's Avatar
    Jan 2008
    Germany
    1,272
    8,501
    22
    Blog Entries
    If so, then your concepts should now be clear regarding data transfer....
    In the end it is just an AXI bus, one side is master and the other side is slave.
    FPGA enthusiast!
