Results 1 to 5 of 5
    Points: 32,618, Level: 44
    Sep 2008
    cambridge
    6,791
    32,618
    44
    Passing radiated EMC with an SMPS involves an element of luck...how much agree?
    I once worked with one of the UK’s finest SMPS design engineers. They were working for the same company as myself at the time. They had already designed many of the SMPS PSU’s as used by the British military.
    They once were talking about trying to get SMPS’s through radiated EMC without the SMPS being in a metal case, and without any metal shielding being used around the PSU or its components, whatsoever…..
    ….In relation to this, this excellent designer said to me…..if you have designed an (non metal enclosed) SMPS and it has passed conducted EMC, and it has been layed out as good as it possibly can be using EMC layout rules (eg keep power switch current loops as minimal in area as possible etc etc)……and supposing this SMPS fails on radiated emissions…..then there are no exact calculations that you can do to get it to pass radiated EMC…..but rather, one simply has to “sprinkle” in ferrite beads and common mode chokes, and Y capacitors and cable ferrites like “currents in a cake”, until you get a pass.
    Please discuss if you agree with this?
    Passing radiated EMC for an SMPS when one has a metal casing is far , far easier, of course, but thats not what they were talking about.
    Points: 39,557, Level: 48
    Mar 2008
    USA
    6,387
    39,557
    48
    Re: Passing radiated EMC with an SMPS involves an element of luck...how much agree?
    Many of the "sprinkles" you mention look more like
    conducted emissions stuff. Of course power lead
    can do both.
    Why you'd expect a calculation to do anything for
    radiated emissions after the fact eludes me.
    Practices aimed at radiated emissions overlap but
    are not all covered by conducted emissions practices.
    Large current loops and long wires carrying switching
    waveforms don't do much of anything as regards
    conducted emissions. Likewise open magnetic path
    inductors.
    What I think you'd want, is on-the-bench ability to
    do a good enough "poor boy radiated emissions" test.
    Like maybe a cast-off microwave oven for a quiet
    chamber, and a spectrum analyzer with a sniffer
    probe. You'd have some work to do in figuring out
    what kind of reading there, equates to a passing
    reading at a real EMI test house, but that might be
    as simple as putting one of your already-tested
    versions that you have a detailed test report for,
    and see what the spectrum analyzer says. Draw
    your "frequency mask" on the screen in crayon
    and there's your cut-and-try goal / feedback.
    Points: 10,810, Level: 24
    Aug 2015
    1,753
    10,810
    24
    For plastic case you need a topology that is inherently very quiet in the first place, and heatsinks all tied to +Vcc or 0v, - this is why we design resonant converters for many of our products ...
    Sprinkling ferrite beads, etc, is best done by some one who has a fair idea of their exact effect in the partic location ...
    Sep 2008
    cambridge
    6,791
    32,618
    44
    Thanks, sorry i mis-worded, i meant that whilst one is doing the design and PCB, there's no fixed way of caluclating what radiated emissions combating components are needed
    Thanks, I have worked in places where none of the plastic cased , hard-switched converters pass radiated EMC, but they still sell the product, on the basis that they are "working on it".
    I very much agree that passing radiated emissions to domestic level, with a hard-switched SMPS in a purely plastic enclosure, is not particularly possible at all.
    I believe that with eg an offline flyback, it is not possible to pass radiated EMC to domestic level (EN55032 class B) unless one uses some kind of metal foil screen round the product or metal case......or at least a metal box over the switching node, say.
    Yes i agree, sprinkling the beads is best eg as close as possible to the output rail of an on-board smps converter.....eg, right by the output caps of it....also, ferrite beads on the pcb traces just before they go to the outside world via the connectors.
    Points: 12,651, Level: 27
    Feb 2010
    UNITED KINGDOM
    1,981
    12,651
    27
    I've done SMPS's in non metal cases that have passed EMC requirements, care and understanding of the beast is what you need, break it down into little bits and its easier, like all circuits, split it into loops and minimise the loops, avoid interaction between loops both capacitive and inductive as much as possible and keep switching currents contained, that includes the 0V especially.
