Results 1 to 4 of 4
    Member level 5
    Points: 1,428, Level: 8
    Apr 2014
    Belgium
    89
    1,428
    8
    LTspice Wolfspeed mosfet model doesn't seem to be working
    I've set up a simple circuit in LTspice using a model of Wolfspeed's C3M0075120K. I'm feeding the gate a square wave but I'm only seeing tiny current spikes at rise and fall going through the mosfet.
    This probably isn't the ideal way to drive a mosfet, but it's just a simple test I set up after discovering the problem while trying to drive a half-bridge using a model of the UCC21520 isolated gate driver (it worked fine until I swapped the existing mosfets for these ones).
    Am I doing something wrong or should I contact Wolfspeed?
    Datasheet: C3M0075120K
    Circuit: files.zip
    Advanced Member level 2
    Points: 4,641, Level: 16
    Nov 2013
    686
    4,641
    16
    Re: LTspice Wolfspeed mosfet model doesn't seem to be working
    Connect disconnected pins too (Tj Tc). Don't let them floating. I see 2.4A if they are grounded.
    "Try SCE to AUX." /John Aaron/
    Points: 77,038, Level: 67
    Apr 2014
    15,609
    77,038
    67
    try to connect V1 Minus directely to GND instead of KS.
    Member level 5
    Apr 2014
    Belgium
    89
    1,428
    8
    Thanks for your replies.
    Connecting Tj and Tc to ground fixed my issue. I thought I could leave them floating because when searching the internet for a fix, I came across this manual. On page 7, it says Tj can be left floating, and it says Tc can be left floating, but I failed to read the highlighted note which says one of them should be connected to a voltage source.
