Results 1 to 2 of 2
    Newbie level 1
    Points: 17, Level: 1
    Aug 2019
    17
    Comparator gives wrong Output
    Hi guys,
    I had been practicing a few problems in verilog and got stuck on this :
    Question : write a program so that output should be 1 when 'x' is greater than or equal to 'y'
    x and y are binary
    My logic module:
    Code Verilog - [expand]
    module comparator(
    input x,
    input y,
    output z);
    assign z = ~y + x ;
    endmodule
    My stimulus/ test-bench module :
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    `timescale 1ns / 1ps
    module stimulus;
    reg x;
    reg y;
    wire z;
    comparator uut (
        .x(x),
        .y(y),
        .z(z)
    initial
    begin
    x=0;
    y=0;
    #20 x=1;
    #20 y=1;
    #20 x=0;
    #40;
    end
    initial
    begin
    $monitor("x=%d, y=%d, z=%d \n",x,y,z);
    end
    endmodule
    OUTPUT OBTAINED:
    Please Help with the above issue, output is shown as 0 when x=1 and y=0.
    Thank you!!
    Points: 31,335, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,235
    31,335
    43
    Re: Comparator gives wrong Output
    Since the question wants you to compare values for greater than the inputs x and y should not be single bits but should instead be a vector, so they can be more than just 1'b1 and 1'b0.
    If they are supposed to be 1-bit then the assignment z = ~y + x is wrong since adding won't tell you if x >= y
    It should be simply z = ~(~x & y); // result is 0 only if x < y, otherwise if x==y or x>y it is 1
