Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
    Full Member level 4
    Points: 981, Level: 7
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Pulse transformer output measured vs. calculated?
    Hi friends!
    I have a 1000 ohm resistor connected to the secondary winding of my pulse transformer, and I'm measuring voltage and current which is all fine. But then I want to e.g. calculate the voltage by applying ohms law - then the calculated voltage is not even in the same range as the measured voltage, so there must be a problem somewhere, either my calculation, measurement and/or expectations? What do you think?
    X-axis is nano-seconds...
    Points: 30,418, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,418
    42
    Re: Pulse transformer output measured vs. calculated?
    While calculating Voltages and Currents with Pulse Transformer, how did you model it ?? Because Ohm's Law cannot be applied to Transient Domain in which is your case.
    I mean, you cannot find Voltages and Currents by simply inserting Ohm's law ,instead you have to know Model of the Pulse Transformer and you have to use State Variable Technique to find Transient and Private ( Steady-State) Solution of Integro-Differential Equation of the circuit.
    You may use a Transient Simulator to predict the response..
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Quote Originally Posted by BigBoss View Post
    Actually it's a physical circuit, not a simulation. And of-course I was wrong applying ohm's law. Basically I just wanted to check if calculated would yield something close to measured in order to (perhaps) know if my measurements are way off, so how do you suggest I go about that?
    And what do you mean by "model" of the pulse transformer?
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,418
    42
    Quote Originally Posted by Swend View Post
    I suggest you extract a accurate model of the Pulse Transformer ( it might be simple or complex) then use a simulator because calculating Voltages and Currents of such a circuit will be very difficult even more erroneous.I believe the manufacturer of that Pulse Transformer has a more or less accurate model, request it..Then you can compare measurements and simulations to crosscheck the failing point..
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    I hear what you are saying, but there are some issues with that. First is that what's on the primary side cannot be simulated, and secondly I'm the manufacturer of the pulse transformer which a simple air-core transformer.
    But what if I measure the inductance of each winding and use LTSpice to couple two coils together, then apply the physical primary side waveform to the simulated primary? would that yield a usable simulation result on the secondary side?
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,418
    42
    OK, if you are able to measure primary and secondary side of the transformer independently, you can use a "Lossy Transformer Model" that can be found in the literature and use it in LTSpice simulations.
  7. #7
    Points: 11,163, Level: 25
    Aug 2015
    1,814
    11,163
    25
    Air core xfmr's are notorious for very high magnetising current loading the driving voltage ( i.e. pulling it down), and not so great coupling to the sec ...
  8. #8
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Yes, could that be the reason that the voltage drops on both primary and secondary when I add more winding on secondary? I'm a little bit puzzled by that, could it have something to with the fact that I connect one side of the primary and one side of the secondary to 0V (GND), which I had to do because I don't have diff-probe yet?
    Also I would like to have a non-air core, but I really can't find any suitable power cores that can do 1MHz.
  9. #9
    Points: 260,228, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,442
    260,228
    100
    How do you measure it? Sure that the probes don't affect the circuit? The question isn't clear at all.
  10. #10
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    For voltage, a resistive 1000:1 voltage divider 100M/100K. For current, a Rogowski coil.
    I'm sure that it does, but I use the same measurement technique on the primary, so I'm hoping that any measurement errors are the same on both sides, as I'm satisfied with just a approximate primary:secondary average power ratio.
    I have made measurements using one approach (see post #1) and I would like to use an alternative approach and compare results. So if both results are in the same ball-park I would have more confidence in the first result. Or if there is another way to do it, I'm all ears.
  11. #11
    Points: 17,233, Level: 31
    Nov 2012
    3,148
    17,233
    31
    In response to a voltage pulse, the current increases linearly; that is clearly seen in the graph.
    In both the plots, I see considerable high frequency ringing. Both voltage and current plots show the same effect (also same frequency).
    I presume you are measuring the voltage on the primary side and the current on the secondary side using the same (or identical) probe.
    Your probe is not responding well to the square pulse. You can use Ohm's law for the 1K resistor only (not for the pulse transformer).
  12. #12
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Quote Originally Posted by c_mitra View Post
    There is no square pulse anywhere, what you are seeing is the pulse.
  13. #13
    Nov 2012
    3,148
    17,233
    31
    I am not quite sure. How are you generating the pulse?
    The waveform seen is typical ringing process (it hit a bell and it produces sound that slowly dies in intensity).
    I still suspect that the primary cause is a square (or rectangular) pulse that hits a resonant circuit. You catch that in the scope but you cannot see the original pulse.
    The current curve is on a slope but why? But that is the typical response of a voltage pulse.
    Is your probe on a DC coupled mode? It looks you are using AC coupling.
  14. #14
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,442
    260,228
    100
    Is it a similar divider as in your other thread?
    If so, I doubt that the voltage waveform isn't reproduced correctly. Similarly, what kind of Rogowski coil and integrator circuit are you using? Did you calibrate voltage and current probes with a test generator?
  15. #15
    Nov 2012
    3,148
    17,233
    31
    If so, I doubt that the voltage waveform isn't reproduced correctly....
    Once you use a voltage divider, your bandwidth is also getting scaled down in the same ratio, right? Similar to gain-bandwidth product
    Plus, frequency compensation should be done with this divider in place, because the big resistor adds more capacitance. Sometimes the small adj cap will be at its end and external compensation has to be done.
    I too think that there are problems with the measurements.
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,442
    260,228
    100
    With an estimated capacitance of 1 pF for the 100 Mohm resistor, you get a zero at 1600 Hz. A single 1 nF compensation capacitor can at least improve the transfer function.
  17. #17
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    It's a commercial thing, if I were to discuss that in public, it would become public domain and then it wouldn't be commercial anymore, I'm sure you can appreciate that, I'm not trying to be a smarty-pants. But what I can say is that if you use a resistor instead of a reactive component, the ringing will gradually diminish with increasing resistance, until about 1.5Kohm when the pulse becomes a smooth exponential decay. But a smooth exponential decay does not produce the desired effect, it has to ring as much as possible as long as it does not become pure AC. So that's why I'm pretty sure there is no square anywhere to be seen.
    Yes. And I will be checking it as you said, always meant to get around that but other stuff that I needed to learn was piling up so I kind of repressed it and just put it on the todo list.
    Well similarly that was also a steep learning curve, after reading a dozen of scientific papers on rogowski coils I decided to roll my own. And I still have doubts about my calculations, as I found that there are no two papers that agree or use the same calculation methods, there is always a small (but significant) difference in the way it is being calculated. But I was content with two identical coils, because then I could at least measure a relative difference, which was my first objective. And only when that objective was reached (which was several months ago) I would review my calculations and have it calibrated against a known current, but it's still on the todo list.
    So I use my own home-rolled coil, connect it to the scope probe x10, dump the trace to a file and then run it through a script which does the integration and other stuff. I found that it would be too cumbersome to make an active integrator and it would still be error prone as I have nowhere to calibrate it.
  18. #18
    Nov 2012
    3,148
    17,233
    31
    No, I do not wish to know the internal details. I just want to know if you substitute a resistor instead of the pulse transformer, what kind of waveform you will get? say you use a 1k or 10k resistor instead of the transformer primary.
    But you need to make sure that your measuring instrument is not contributing to the ringing.
    Better to use a series resistor of 1k and 1R and measure the voltage across the 1R to reduce the applied voltage.
  19. #19
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    if you use a resistor instead of a reactive component e.g. the transformer, the ringing will gradually diminish with increasing resistance, until about 1.5Kohm when the pulse becomes a smooth exponential decay.
  20. #20
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Here is the revised measurement with my newly compensated voltage dividers
    X-axis is nanoseconds
    "hi" = primary
    "lo" = secondary
    This is measured with 30Kohm load on the secondary.
