Results 1 to 14 of 14
    Junior Member level 3
    Points: 322, Level: 3
    Jul 2018
    27
    322
    interfacing IR remote using NEC protocol - mikroc for PIC
    I am trying to interface IR remote control(NEC Protocol) using 16f887 pic microcontroller. Coding objective is to read the IR signal and has to be display the equalant HEX value of command and address. While testing in hardware IR signal is not detecting but got random output. Tried a lot to solve the issue but failed. Here I have attached the coding kindly help me out. Thanks in advance.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    sbit LCD_RS at Rd1_bit;
    sbit LCD_EN at Rd2_bit;
    sbit LCD_D4 at Rd4_bit;
    sbit LCD_D5 at Rd5_bit;
    sbit LCD_D6 at Rd6_bit;
    sbit LCD_D7 at Rd7_bit;
    sbit LCD_RS_Direction at TRISd1_bit;
    sbit LCD_EN_Direction at TRISd2_bit;
    sbit LCD_D4_Direction at TRISd4_bit;
    sbit LCD_D5_Direction at TRISd5_bit;
    sbit LCD_D6_Direction at TRISd6_bit;
    sbit LCD_D7_Direction at TRISd7_bit;
    // End LCD module connections
    bit nec_ok;
    char text[5];
    unsigned short nec_state, command, inv_command, i;
    unsigned int address, timer_value;
    unsigned long nec_code;
    void Interrupt() {
      if (RBIF_bit && RBIE_bit){         // PORTB change ISR
        RBIF_bit = 0;
        if(nec_state != 0){
          timer_value = (TMR1H << 8) + TMR1L;           // Store Timer1 value
          TMR1H = 0;                                    // Reset Timer1
          TMR1L = 0;
        switch(nec_state){
         case 0 :                                       // Start receiving IR data (we're at the beginning of 9ms pulse)
           TMR1L = 0;
           TMR1ON_bit = 1;                              // Enable Timer1
           nec_state = 1;                               // Next state: end of 9ms pulse (start of 4.5ms space)
           i = 0;
           break;
         case 1 :                                       // End of 9ms pulse
           if((timer_value > 9500) || (timer_value < 8500)){         // Invalid interval ==> stop decoding and reset
             nec_state = 0;                             // Reset decoding process
             TMR1ON_bit = 0;                            // Disable Timer1
           else
             nec_state = 2;                             // Next state: end of 4.5ms space (start of 562Ás pulse)
           break;
         case 2 :                                       // End of 4.5ms space
           if((timer_value > 5000) || (timer_value < 4000)){
           else
             nec_state = 3;                             // Next state: end of 562Ás pulse (start of 562Ás or 1687Ás space)
           return;
         case 3 :                                       // End of 562Ás pulse
           if((timer_value > 700) || (timer_value < 400)){           // Invalid interval ==> stop decoding and reset
           else
             nec_state = 4;                             // Next state: end of 562Ás or 1687Ás space
           return;
         case 4 :                                       // End of 562Ás or 1687Ás space
           if((timer_value > 1800) || (timer_value < 400)){           // Time interval invalid ==> stop decoding
             return;
           if( timer_value > 1000)                           // If space width > 1ms (short space)
             nec_code = 1 << (31 - i);       // Write 1 to bit (31 - i)
           else                                              // If space width < 1ms (long space)
             nec_code = 0 << (31 - i);    // Write 0 to bit (31 - i)
           i++;
           if(i > 31){                                  // If all bits are received
             nec_ok = 1;                                // Decoding process OK
             RBIE_bit = 0;                              // Disable PORTB change interrupt
             return;
      if (TMR1IF_bit){                 // Timer1 ISR
        TMR1IF_bit = 0;                // Clear Timer1 overflow flag bit
    void main() {
     OSCCON = 0X70;
      trisd = 0x00;
      trisb0_bit = 1;
      ansel = 0x00;
      nec_ok = 0;
      nec_state = 0;
      ANSELH = 0;                      // Configure all PORTB pins as digital
      Lcd_Init();                      // Initialize LCD module
      Lcd_Cmd(_LCD_CURSOR_OFF);        // cursor off
      Lcd_Cmd(_LCD_CLEAR);             // clear LCD
      TMR1IF_bit = 0;                  // Clear Timer1 overflow interrupt flag bit
      TMR1IE_bit = 1;                  // Enable Timer1 overflow interrupt
      T1CON = 0x10;                    // Set Timer1 clock source to internal with 1:2 prescaler (Timer1 clock = 1MHz)
      INTCON = 0x90;
      INTF_bit = 0;
      INTE_bit = 1;
      IOCB0_bit = 1;
      OPTION_REG = 0XC0;
      Lcd_out(1,5,"welcome");
      Lcd_out(2,2, "dear");
      delay_ms(1000);
      Lcd_cmd(_lcd_clear);
      Lcd_Out(1, 1, "Address:0x0000");
      Lcd_Out(2, 1, "Com:0x00 In:0x00");
      delay_ms(1000);
      while(1) {
        while(nec_ok)                // Wait until NEC code receiver
        nec_ok = 0;                    // Reset decoding process
        nec_state = 0;
        address = nec_code >> 16;
        command = nec_code >> 8;
        inv_command = ~command ;
        IntToHex(address, text);       // Save address in string text with hex format
        Lcd_Out(1, 11, text);          // Display address
        ByteToHex(command, text);      // Save command in string text with hex format
        Lcd_Out(2, 7, text);           // Display command
        ByteToHex(inv_command, text);  // Save inverted command in string text with hex format
        Lcd_Out(2, 15, text);          // Display inverted command
        RBIE_bit = 1;                  // Enable PORTB change interrupt
    Advanced Member level 1
    Points: 977, Level: 7
    hexreader's Avatar
    Apr 2011
    England
    490
    977
    7
    Re: interfacing IR remote using NEC protocol - mikroc for PIC
    Shouldn't that be?
    while(!nec_ok); // Wait until NEC code receiver
    With a ! and a ;
    Jul 2018
    27
    322
    Will try that and update you for the same.
    hexreader's Avatar
    Apr 2011
    England
    490
    977
    7
    The project will still not work.
    You have failed to enable RBIE before the while(1) loop.
    What CPU clock frequency are you using?
    Jul 2018
    27
    322
    * Yes sir, as you said output is not coming after changing the while condition. Not even random output is received.
    * Mu cpu clock frequency is 1.8 GHz.
    * IF I enable RBIE before loop, lcd is simply remains blank. nothing works.
    Help me out..
    Points: 80,963, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,270
    80,963
    69
    Wow! That's a fast PIC!
    I think hexreader was referring to the PIC clock frequency not your PC.
  7. #7
    Jul 2018
    27
    322
    I was thinking the same brain, My MCU frequency is 8 MHz.
  8. #8
    hexreader's Avatar
    Apr 2011
    England
    490
    977
    7
    Your code seems hopelessly confused.
    You enable RB0 external interrupt and PORTB interrupt on change, yet you handle only interrupt on change.
    Why are you using both sorts of interrupt?
    Where is the code for changing from falling edge detection to rising edge detection?
    Did you write this code, or did you find it on the internet?
  9. #9
    Jul 2018
    27
    322
    hexreader,
    I got this code from internet. While trying to execute in hardware I got this sort of problems. I already wrote a code for simple interrupt and executed successfully. But this seems bit of complication, so decided to take code from web. But still I can fix the issues if you guide me...
  10. #10
    hexreader's Avatar
    Apr 2011
    England
    490
    977
    7
    You should have left that code where it was. It is complete garbage.
    I am close to a fixed version, but it currently works for one IR remote that I own, but not a second TV remote.
    Not sure if this forum allows zip file to be attached, but I will try....
  11. #11
    Jul 2018
    27
    322
    Hexreader,
    Many Thanks for sharing the code. I will test and update you for the same.
  12. #12
    Jul 2018
    27
    322
    Hi hexreader,
    It is working but most of the times it gets strucked, after few button press. Then we have to restart it again to accept signal. What could be the issue. I'm attaching my hardware image kindly suggest the suitable solution. Thanks in advance. Click image for larger version.
  13. #13
    hexreader's Avatar
    Apr 2011
    England
    490
    977
    7
    Yes, I have exactly the same problem. It is a software problem, not a hardware problem
    Still working on it....
    May take a long time, as I do not fully understand how the original code was supposed to work and it is all a bit of a mess.
  14. #14
    Jul 2018
    27
    322
    Hexreader,
    Thanks for your assistance. I will try the same from my side and update to you with progress.
