+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 2
    Points: 331, Level: 3
    Join Date
    Sep 2018
    Posts
    24
    Points
    331
    Level
    Problem about amplifier biasing circuit
    For CMOS integrated LNA in this picture, is LD a part of the matching network?
    Usually if LD and C1 is a bias Tee, LD should be a RF choke and C1 should be a DC blocking cap. But such large L and C can't be built on chip. So I assume they are just matching network. But why do we sometimes need a bias Tee? If LD is not large, will the amp be affected if VDD is not an ideal voltage source?Click image for larger version.
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 30,375, Level: 42
    BigBoss's Avatar
    Join Date
    Nov 2001
    Turkey
    Posts
    4,456
    Points
    30,375
    Level
    42
    Re: Problem about amplifier biasing circuit
    Ld can be used either Matching Purpose or RFC.Depends on the Designer..
    But if this LNA is a RFIC type Matching is not very necessary due to very short distances in RFIC, Ld in this case might be RF Choke Coil.It does not have to be very large Inductor.
    •   AltAdvertisement
  3. #3
    Join Date
    Sep 2018
    Posts
    24
    Points
    331
    Level
    But that's where I'm confused. If Ld doesn't need to be large, why do we sometimes need a RF choke?
    •   AltAdvertisement
  4. #4
    Points: 33,915, Level: 44
    Join Date
    Oct 2001
    Posts
    4,841
    Points
    33,915
    Level
    44
    Sometime Ld is replaced by a resistor at the cost of losing efficiency of the circuit.
    Also there are situations (for narrow band circuits) when Ld is not a choke, but is an inductor which together with the output reactive components (in this case, C1 and C2) is used to make the output impedance matching network.
  5. #5
    BigBoss's Avatar
    Join Date
    Nov 2001
    Turkey
    Posts
    4,456
    Points
    30,375
    Level
    42
    Quote Originally Posted by sqx View Post
    In order to expand The Voltage Headroom.If we use a Resistor, we'll loose Voltage Headroom..
    RFC can sometimes be a part of Matching Circuit moreover even Bonding Wires are also be used for Matching Circuit or RFC.. There are many options..
