Results 1 to 6 of 6
    Member level 3
    Points: 753, Level: 6
    Mar 2017
    60
    753
    Power Amplifier Design
    For load-pull simulation to extract optimum load impedance. How to set input power ? According to what?
    Thanks in advanced
    Points: 30,003, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,381
    30,003
    42
    Re: Power Amplifier Design
    Output Power should be vicinity of P1dB. In fact, there isn't any convention about that because some manufacturers use P3dB some of them P1dB.
    Nevertheless, P1dB Compression Point is chosen and Input Power is adjusted in according with that.Because Optimum Load will be used to achieve max. [specification]
    [specification]: max Pdelivered or max. Efficiency or max. Power Gain..
    Member level 3
    Mar 2017
    60
    753
    Quote Originally Posted by BigBoss View Post
    Thanks for the valuable information. Is the same thing is considered for doherty sub-amplifiers (main & auxiliary)? I want to do a correct DPA design, but still confusing about load pull setting such as input power level for each one of the sub-amplifiers
    Points: 53,543, Level: 56
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,720
    53,543
    56
    When you said Power Amplifier Design I thought it would drive an 8 ohms speaker.
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,381
    30,003
    42
    Quote Originally Posted by Mabrok View Post
    You should drive the PA until the PA enters into SAT mode in order to observe the Efficiency in Main and Aux. Amplifier regions. Back-Off effect in Efficiency can be observed with this method ..
    Full Member level 3
    Points: 1,131, Level: 7
    Jan 2019
    Belgium
    163
    1,131
    7
    I do loadpull for the main amplifier at two points:
    1. Just before the peaking amplifier turns on and begins to significantly do "load modulation".
    2. When both the amplifiers are saturated.
    For the peaking amplifier, I do loadpull at the peak point where both the amplifiers are saturated.
