Results 1 to 4 of 4
    Newbie level 1
    Points: 41, Level: 1
    Jul 2019
    41
    Difference between Differentiators and Comparators
    Please, I'm a bit confused about the concept of this two amplifiers. In what ways/why are Differentiators different from comparators?
    Points: 12,636, Level: 26
    Apr 2010
    1,918
    12,636
    26
    Re: Difference between Differentiators and Comparators
    differentiators produce the differentiation of input signal waveform.
    (i.e. d/dt of input signal)
    comparator compares the voltages between the NonInv and Inv i/ps of opamp and produce a polarised output based on their difference in magniudes.
    Advanced Member level 2
    Points: 2,884, Level: 12
    Aug 2016
    507
    2,884
    12
    In addition to what srizbf said, a differentiator detects transitions of the input signal. It produces a spike at the output when the input transitions.
    The comparator output switches from low to high as the input signal increases and equals the reference and from high to low as the input signal decreases and equals the reference. Usually, there is a hysteresis implemented around the reference voltage.
    --Akanimo.
    Points: 52,908, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,945
    52,908
    56
    A differential detector is the input stage of a comparator.
    A differentiator performs a calculus function, differentiation. Its the counterpart of integration.
