Results 1 to 6 of 6
    Full Member level 3
    Points: 1,132, Level: 7
    Jan 2018
    183
    1,132
    7
    How to increase high frequency output power
    Hi, I need suggestions, in general, on how to increase high frequency output power. I was using inductive peaking but I don't get the flat response in the frequency range
    Full Member level 3
    Points: 1,260, Level: 8
    Jan 2019
    Belgium
    183
    1,260
    8
    Re: How to increase high frequency output power
    Can you maybe elaborate on what you mean by "high frequency output power"? If you are referring to higher power at high frequency, then inductive peaking will not help (and of course you won't get flat response with ideal inductors. Putting in a finite quality factor will improve the 'frequency range' but I am still confused how does it relate to power)
    Full Member level 3
    Jan 2018
    183
    1,132
    7
    For example in the below case
    Points: 30,247, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,425
    30,247
    42
    It depends on many variables.It's not easy to say..
    Output Power may be function of Power Gain, Load,Transistor (Amplifier/Active Device ) itself,Matching,Parasitic Elements,Package, etc.
    If I think that practically, it seems to me a "Mismatch Effect" but it might also be another thing..Hard to say..
    Points: 52,642, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,884
    52,642
    56
    Quote Originally Posted by circuitking View Post
    output power
    Can this be solved by impedance matching? Normally that is associated with the goal to maximize power transfer.
    Input arrives as a combination of voltage and current. The matching network raises voltage and reduces current (or the other way around). Values are selected so that the outgoing signal drives the next stage in the most efficient manner.
    A passive network might consist of one or more LC arrangements.
    Full Member level 3
    Jan 2019
    Belgium
    183
    1,260
    8
    The curve that circuitking has shared shows a very wide region of operation. Obtaining matching across such a wide range is quiet difficult. Typically, it would require the matching circuits to be tuned for different frequencies.
    Is it just one PA or there are multiple PAs operating at different frequencies? Can you share the source of this image?
