Results 1 to 16 of 16
    Points: 32,579, Level: 44
    Sep 2008
    cambridge
    6,786
    32,579
    44
    BJT V(ce) ON in common emitter mode
    For an FMMT491A BJT with 2.7mA flowing into its base and set up in common emitter mode….is there any set of circumstances (temperature, i(ce) etc etc) which might ever result in its Vce(ON) voltage ever being greater than 0.5v?
    Its collector current is always less than 40mA
    From the datasheet I see not, but is there any gremlin situation?
    FMMT491A datasheet
    https://www.diodes.com/assets/Datasheets/FMMT491.pdf
    Points: 77,038, Level: 67
    Apr 2014
    15,609
    77,038
    67
    Re: BJT V(ce) ON in common emitter mode
    I don't expect higher V_CE than 5V with the given values.
    If you see higher V_CE, then you should provide your test circuit..an additional photo could be helpful.
    For low voltage drop I'd use a MOSFET.
    Points: 259,210, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,256
    259,210
    100
    Not more than 10 to 20 mV Vce with the given Ic and forced B values.
    Sep 2008
    cambridge
    6,786
    32,579
    44
    Is there any situation , where literally any SOT23 or SOT323 NPN with VCE voltage rating of <65V may suffer a drop in Hfe down to less than 15?...surely such a situation simply does not exist?...even in the cheapest such NPN?…….(considering Ib <4mA ).
    If so, please state the situation and NPN concerned
    Points: 30,226, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,419
    30,226
    42
    -Ib has to be <4mA
    -Vce(sat) has to be >0.5V @ Ic=40mA..
    I wonder what type of application is it ?? If you would Vce(sat)>0.5V, connect simply a resistor ??
    Sep 2008
    cambridge
    6,786
    32,579
    44
    thanks, we have BJTs with very very little base current in them (to save energy)....and we wonder if there Hfe will always be big enough to get them to turn on fully and have a vce(on) of <0.3v.
  7. #7
    Points: 53,595, Level: 56
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,730
    53,595
    56
    hFE is measured when the transistor is linear with plenty of Vce voltage and not saturated.
    Your transistor is a saturated switch and like most little transistors its datasheet says it saturates well when its base current is 1/10th its collector current.
  8. #8
    Points: 10,713, Level: 24
    Aug 2015
    1,736
    10,713
    24
    you can never get Vce < Vbe in common emitter config. For max Hfe at a given Ic you need to carefully select a xtor from its data sheet, Hfe falls off for very low Ic
  9. #9
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,419
    30,226
    42
    Quote Originally Posted by treez View Post
    The solution comes into my mind is Darlington Transistor with Low Vce(sat) feature.. Am I wrong ??
    Or using a simply a MOS ?? Zero bias current and very low sat voltage ..
    I'm still not sure what your purpose is..
  10. #10
    Audioguru's Avatar
    Jan 2008
    8,730
    53,595
    56
    Of course you can have a common-emitter transistor saturate with its Vce much less than its Vbe. it is called "saturation".
    Quote Originally Posted by BigBoss View Post
    The input transistor of a darlington transistor prevents the output transistor from saturating with a low Vce(sat). A TIP120 power Darlington has a max allowed continuous current of 5A but its typical Vce(sat) at only 1A is 1V.
    A TIP41 power transistor is not a Darlington and its max allowed continuous current is 6A, its typical Vce(sat) at 1A is 0.15V.
    Wikipedia says, "Another drawback of the Darlington pair is its increased "saturation" voltage. The output transistor is not allowed to saturate."
  11. #11
    Aug 2015
    1,736
    10,713
    24
    I meant when the emitter is common to the load sorry, - emitter follower - which seemed what the OP was trying to do
  12. #12
    Audioguru's Avatar
    Jan 2008
    8,730
    53,595
    56
    No. The op is using the transistor as a common-emitter saturated switch and does not know that hFE is not used for a saturated transistor.
  13. #13
    Sep 2008
    cambridge
    6,786
    32,579
    44
    thanks , i appreciate that if a NPN in CommEm has <0.3v across its Collec-Emit (what we want), then it is going to be saturated......thing is, we find ourselves having to look at hfe, to see if it will be high enough so that we do end up in saturation...even though hfe doesnt then pertain to operation in saturation...
  14. #14
    Audioguru's Avatar
    Jan 2008
    8,730
    53,595
    56
    Don't you trust the datasheets? They guarantee that ANY transistor that has an hFE high enough to pass will saturate at the spec'd low saturation voltage. Then the base current MUST be 1/10th the emitter current. Some high hFE European transistors say 1/20th the collector current. But for you to want less base current then you must test each and every transistor to find any that can do it.
    The graphs on a datasheet apply only to a "typical" transistor, not all of them, and many actually saturate fairly well with a low base current.
  15. #15
    Aug 2015
    1,736
    10,713
    24
    for power xtors, most data sheet specify Vce ON for saturated gain, usually Ic/Ib = 10 or 5
    Zetex did a range of xtors designed to give very low Vce on for quite modest base drive Ic/Ib = 20 or so
    I recommend looking up these types on the new owners website - they may be just what you are looking for
    Else a mosfet with 1V drive ( they do exist )
  16. #16
    Aug 2015
    1,736
    10,713
    24
    else you have to find a xtor that is spec'd for a min gain at amin temp that will fall into your desired range, as mentioned above - if the Ice goes up - the Vce will go up - for a given base current.
