[SOLVED] What the best driver for controlling SSRs using a 5v uC
Xenobius
Member level 5
I am currently building a small reflow oven for the fun of it and have settled on using 2 Solid State Relays (mounted on heatsinks and all that) and controlling them using an arduino. My question is, with the parts that I have available, what do you recommend I use to switch on/off the relays? One certain thing is that I cannot/shouldn't directly connect the arduino to both relays simply because they draw a maximum of 25mA and the Arduino is 20mA max.
SSR specs:
Load Voltage24-380VAC
Control Voltage3-32VDC
Control Current3-25mA
On Voltage<1.5VAC
ON/Off Time<10mS
Parts available:
Mosfet78-SQ3427EEVhttps://eu.mouser.com/datasheet/2/427/sq3427ee-101865.pdf
NPN TransistorBCX5416E6327https://eu.mouser.com/datasheet/2/196/bcx54_bcx55_bcx56-59453.pdf
PNP TransistorPMBT3906https://assets.nexperia.com/documents/data-sheet/PMBT3906.pdf
Most solid state relays with low voltage DC control input have opto coupler with series resistor as input circuit.
Did you check the input current with 5V control voltage? I would expect below 10 mA. If so, it can be well driven by µP pin without driver transistor.
No the relays are still on their way but im going with datasheets while I design the circuit. You may be right however I think I will still feel better off with 2 transistors also considering its a one time project and I have hundreds of them :)
Hi again, so is this what you meant when you said SSR in Collector?
The 'CONN-SIL2' will be the 2 inputs of the SSR. Thanks
That is correct. Double check the SSR has an internal series resistor to limit the current as described by FvM. Almost all of them do.
