Designing IRON-CORE TRANSFORMER No Load Current Problem
SS1_Raptor
Junior Member level 1
Dear friends hi
I am designing IRON-CORE TRANSFORMER
Step Up
Vin = 24V
Vout = 220V
Ferq = 50HZ
Power = 500Watt
What is the general rule for calculating no load Current ?
is this true if i set the no load current high i can get a better momentary Current at Output ?
Generally, if i momentarily connect the full load to the transformer How much time is accepted. To get the full current?
Thanks a lot
Presumed you are "connecting" the load with a fast switch, e.g. a triac, to the secondary of a regular 50 Hz transformer you can expect a finite current rise time in a 10 us range due to transformer leakage inductance.
"No load current" or magnetizing current depends on main inductance and is not related to leakage inductance or vice versa.
