Drive motor through IRF520 MOSFET module and Arduino
sugandha123
I am trying to run the motor through Arduino and IRF520 Mosfet Driver Module but the motor does not come to their its own Home location through microlimit switch.
But If I drive through relay it comes at its own home location. Relay connection was
Relay
Common shorted with NC connected with NO of Motor
NO of relay is connected to Ground
Gnd and 12V of Motor is connected to 12V Power supply
I have attached an image of the motor module that I am using.
There are six pins in this motor Motor Connections with Relay
I do not know about the connections of the motors with the IRF520 driver module which works exactly same as it is working with the relay module. Please If anyone knows about the connections with MOSFET DRIVER Module please let me know and how to rotate motor 360 degree (On home position) and stop.
please draw the circuit for the arduino, the MOSFET Drive Module and the motor
show the connections between the arduino the mosfet driver and from the mosfet driver to the motor
show all voltage sources and all ground connections
show all wires between the three pieces
please draw the circuit for the arduino, the relay and the motor
show the connections between the arduino therelay and from the relay to the motor
clearly label both circuits
the more clear and complete the information, the more clear and complete a response will be
this may help:
https://robu.in/product/irf520-mosfet-driver-module-arduino-arm-raspberry-pi/
