Results 1 to 4 of 4
    Advanced Member level 2
    Points: 2,155, Level: 10
    Aug 2016
    570
    2,155
    10
    dc current gain variations
    Does hFE vary while BJT is in operation within the specified hFE min/max ranges?
    https://www.mouser.com/datasheet/2/4...01-1144060.pdf
    Points: 259,231, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,258
    259,231
    100
    Re: dc current gain variations
    It does not vary. The min to max range is specified to take account of type variations. If a transistor exemplar shows e.g. B=100 under specific condictions (like Vce=5V, Ic=1A, t=25°C), it will keep this current gain.
    Points: 53,595, Level: 56
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,730
    53,595
    56
    A transistor in operation heats or cools which affects its hFE.
    A transistor in operation has a variable current which also affects its hFE.
    Design a transistor circuit with enough base current so that it works with the minimum or maximum hFE for the varying conditions. Negative feedback is usually used.
    Points: 14,794, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,460
    14,794
    29
    Be aware though, that the specified Hfe is in the linear region. Which in this instance, it means a Vce of at least 5 volts.
    As the transistor approaches saturation, the Hfe will start to drop.
    My batteries are recharged by "Helpful Post" ratings.
