Results 1 to 14 of 14
    Newbie level 3
    Points: 61, Level: 1
    Jul 2019
    61
    When simulating center tapped inductor in ADS
    Hello, I'm drawing and testing center-tapped inductor with ADS simulator. Center-tap will be connected to VDD.
    After drawing inductor,
    I assigned term 1&2 to two ends of inductor and term3 to center tap to simulate s-parameter simulation.
    Setting of term impedances are defaults ( 50ohm ).
    But I think I have to set impedance of term3 to 0 ohm because it will be connected to the VDD.
    Do I have to set impedance of term 3 as a default? or some other value?
    Thank you
    Points: 14,139, Level: 28
    Apr 2014
    2,214
    14,139
    28
    Re: When simulating center tapped inductor in ADS
    Leave the port impedances set to 50 Ohm. The circuit simulator later takes care of the calculating the voltages and currents for the external impedances connected to the model. S-parameters don't work for 0 Ohm reference impedance.
    When you evaluate results for your inductor in differential configuration, the center tap is at 0V due to symmetry anyway.
    https://muehlhaus.com/support/ads-ap...uctor-em-ports
    Newbie level 3
    Jul 2019
    61
    Thank you for your reply
    May I ask one more question?
    I've learned that Q of center-tapped is higher than not tapped one and I wanna exploit this feature.
    Also, in my idea, inductor of inductance of L1 is divided by factor of 2 when we use center-tap.
    However, my center-tapped inductor shows higher inductance and lower SRF.
    So, I'm confused and I'm not convinced with my simulation.
    If you have any idea about this phenomenon, please let me know. Thank you.
    Below figure is my simulation setting and S-parameter plot of it
    Points: 17,003, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    Quote Originally Posted by jwonoh View Post
    Yes.
    See schematics in https://designers-guide.org/forum/Ya...m=1205240723#9
    Apr 2014
    2,214
    14,139
    28
    Quote Originally Posted by pancho_hideboo View Post
    There is no port 3 in your linked post. Which is fine.
    I am working on these inductor simulations for many years, and never heard that. The center tap is a virtual ground when used with symmetric excitation. I think you might refer to differential vs. common mode Q factor.
    I'm not sure what you compare, the full inductor (port 1 to port 2) vs. half of the inductor (port 1 to port 3)? Have a look at my appnote linked above. The important thing is to use the correct excitation - if you drive the inductor single ended from port 1 only, it behaves differently from the differential excitation. Also, that single ended excitation is not the typical use case. You should investigate differential operation.
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    Quote Originally Posted by volker@muehlhaus View Post
    Surely see schematics.
    https://designers-guide.org/forum/At.../Diff_Ind2.jpg
    Port-3 is connected to center tap.
  7. #7
    Apr 2014
    2,214
    14,139
    28
    Then I think your math is wrong for 3-port simulation. It is valid for 2-port simulation.
  8. #8
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    See https://designers-guide.org/forum/Ya...m=1205240723#9
    R0=50
    Sdiff = (s11-s12-s21+s22)/2.0
    Zdiff = 2*R0*(1+Sdiff)/(1-Sdiff)
    freq = xval(s11)
    Ldiff = imag(Zdiff)/(2*pi*freq)
    Qdiff = imag(Zdiff)/real(Zdiff)
    Z1 = 1/y11
    L1 = imag(Z1)/(2*pi*freq)
    Q1 = imag(Z1)/real(Z1)
    https://designers-guide.org/forum/Ya...m=1205240723#8
    Qdiff > Q1
    Consider Ldiff not L1.
    Ldiff= 2*(Ldiff/2)
    It is valid for differential mode excitation.
    For evaluation of L1 and Q1, port-3 must not be connected.
  9. #9
    Apr 2014
    2,214
    14,139
    28
    I just tested it and confirm it works for 3-port simulation also.
  10. #10
    Points: 30,417, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,417
    42
    I couldn't see the proof of Qdiff>Qse ??
  11. #11
    Apr 2014
    2,214
    14,139
    28
    Quote Originally Posted by BigBoss View Post
    My test was to check if pancho's equations also work to create differential data from 3-port S-params where the center tap is connected. That indeed works.
    Here is the comparison of single ended and differential Q for that exact same layout, from the same EM simulation:
  12. #12
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    We don’t see parasitic capacitance at crossing point, if differential inductor is drived differentialy.
  13. #13
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,417
    42
    If we consider the equivalent circuit of an inductor and when we make short circuit P2, corresponding distributed components are becoming short circuit.
    So, the difference which coming from SE and DIFF measurements might be result of this error. I'm saying that is an error because it does not sound very healthy to me.
    In my opinon , DIFF measurement looks like more healthy..
  14. #14
    Apr 2014
    2,214
    14,139
    28
    What post and P2 do you refer to? In my post #11 the center tap is at Port 3 and that's floating in this comparison.
    The difference between single ended Q and differential Q is also seen for the 2-port case, not related to center tap. You are correct that it can be understood by looking at the shunt path in the equivalent circuit.
