Results 1 to 4 of 4
    Full Member level 5
    Points: 3,035, Level: 12
    May 2010
    Poland
    241
    3,035
    12
    Where Can I buy Transformer Core Ferrites for Frequencies ABOVE 200 MHz ?
    I know of 200 MHz ferrites e.g. by National Magnetics Group. Are there any ferrites good for transformers above 200 MHz?
    Full Member level 5
    May 2010
    Poland
    241
    3,035
    12
    Are there really ferrites for multi-GHz frequencies?
    Supposedly Hexaferrite (barium ferrite) works at such frequencies. But I have found information that it has permeability = 1.1, so it is not much gently speaking. If there are such high-frequency ferrites with decent permeabilities, where can I buy them?
    Last edited by FvM; 5th August 2019 at 22:08. Reason: Merged threads "Ask related questions in one thread"
    Newbie level 6
    Points: 525, Level: 4
    Anomis's Avatar
    Mar 2017
    South Korea
    14
    525
    Re: Where Can I buy Transformer Core Ferrites for Frequencies ABOVE 200 MHz ?
    Quote Originally Posted by htg View Post
    i bet there are tons of companies over the world selling your devices, for ex: here is the link
    https://www.mag-inc.com/Products/Fer...-Ferrite-Cores
    here also provides you helpful extent about magnetic materials that are able to answer the second question as well
    hope it helps,
    TM
    Advanced Member level 2
    Points: 1,984, Level: 10
    Aug 2016
    536
    1,984
    10
    Re: Are there really ferrites for multi-GHz frequencies?
    Seems they aren't economical to mass produce otherwise they would likely be found in all the major cellphones, laptops and other devices which make use of wifi and similar RF bands. Log periodics seem the simplest way to broadband reception.
