Results 1 to 3 of 3
    Newbie level 1
    Points: 16, Level: 1
    Aug 2019
    16
    How to Solve the “Naming Error” in the LVS
    Dear All
    I check the net9 in the layout --------------------(1)
    I check the PWM_B,X123/PWM_B in the source--------(2)
    (1)(2)is same.
    Q:where is the error? Thanks!
    Full Member level 3
    Points: 1,386, Level: 8
    Sep 2015
    150
    1,386
    8
    Re: How to Solve the “Naming Error” in the LVS
    You have a number of discrepancies. Start with fixing your port error.
    Newbie level 1
    Points: 19, Level: 1
    Aug 2019
    19
    Hello! Usually if in layout name 1 net and in source name - 2 nets , it means that you shorted PWM_B,X123/PWM_B. Have a look carefully, may be you put extra some vias.
    As life huck you mean put some pin (for exapmle "name1") on net PWM_B and pin "name2" on net X123/PWM_B and then LVS will see shorts and it will be easier to find short.
