Results 1 to 8 of 8
    Advanced Member level 3
    Points: 5,591, Level: 17
    Feb 2014
    793
    5,591
    17
    LTSpice Noise Analyis
    Does anyone understand how LTSpice's noise simulation works under the hood?
    I've used LTSpice extensively but barely touched the noise mode (I'm trying to catch up on my understanding of noise calculations in general). In a couple toy examples it seems almost too good to be true.
    Do the model designers need to explicitly prepare the model for this mode or does it emerge from standard model design practices? My understanding is that spice models can vary a lot under the hood and it seems the quality of the noise model would vary accordingly? Thus I wonder if LT models may be better than the AD models that probably weren't designed with LTSpice in mind from the start?
    Points: 259,376, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,288
    259,376
    100
    Re: LTSpice Noise Analyis
    It's basic SPICE noise analysis considering resistor noise and semiconductor shot noise.
    Also flicker noise parameters for FET and bipolar devices, if used by the respective model.
    Feb 2014
    793
    5,591
    17
    Ok and part of my question is about realistic model expectations.
    For example TI's OPA140 has no noise when simulated in LTSpice's noise mode.
    Of course this is what I expected - performance depends on the quality and makeup of the model. I'm still trying to get a sense of how many models have accurate noise performance.
    Points: 19,003, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,665
    19,003
    33
    One way is to simulate the noise of the model and see how it compares to the specs from the device data sheet.
    Zapper
    Curmudgeon Elektroniker
    Points: 39,561, Level: 48
    Mar 2008
    USA
    6,388
    39,561
    48
    I haven't really experienced anything I'd call "standard
    model design practices" in a pretty long IC design career.
    IME it's always a negotiation and you can't count on the
    noise params being populated in device model statements,
    let alone fitted inside a behavioral / macromodel.
    LTSpice has a lot of tricky stuff below the surface. The
    Yahoo! Group for LTSpice is very active and has a deep
    pile of archived info that might help you out.
    http://ltwiki.org/index.php?title=Undocumented_LTspice
    has some discussion of how LTSpice behavioral OTA does
    noise model fitting (when and if); maybe look at the .model
    or .subckt's referenced models / primitives and see whether
    you have any right to expect noise characteristics out of it.
    Feb 2014
    793
    5,591
    17
    Wait I have to take my last statement back. I simply screwed up the importing of the OPA140 model (symbol was still referencing an ideal model). So on a second quick look the OPA140 and a handful of other imported TI models do have decent correlation between datasheet and simulation noise results.
    For what its worth TI has a paper describing their new model approach:
    http://www.ti.com/lit/an/sboa338/sboa338.pdf
  7. #7
    Feb 2014
    793
    5,591
    17
    On a sort of related note does anyone have an understanding of why instrumentation amplifiers have such high noise?
    For example AD8429 billed as 'ultralow noise' has 45 nV/√Hz output noise. So 45 is the noise at G=1 (input noise is negligible at 1 nV/√Hz) which is quite bad (tons of precision amplifiers are <5).
    Why have an output stage with that high noise when it seems 'easy' to make amplifiers with much less. Are they assuming I'm going to use it at high gains (I'm not, I want a high impedance differential buffer and inst amps with integrated resistors are a cost effective way to buy that)?
    Am I missing something dumb?
  8. #8
    Points: 20,661, Level: 34
    Jan 2011
    3,381
    20,661
    34
    Quote Originally Posted by asdf44 View Post
    Just look at the datasheet. The AD8429 is based on the typical three-amp circuit, so it basically has two cascaded amp stages. When the gain of the first stage is high, its noise dominates the overall noise performance. But if it's gain is low, then the second stage's noise will degrade overall performance. Meeting your requirement (high input impedance, unity gain difference amp) is tricky with this circuit, since the resistors used in the second stage will add significant noise.
