Results 1 to 7 of 7
    Points: 254, Level: 3
    fixit7's Avatar
    Jul 2019
    50
    254
    Minimize effect of IR bulbs on image
    The IR bulbs are great for nighttime surveillance but not really needed when there is ample light.
    As you can see, in this image the IR light is reflecting off the blinds.
    https://imgur.com/uQZxkux
    Is there a way to minimize that effect?
    I looked over the camera and it looks like there is no user friendly way of even getting inside it.
    https://www.cctv.net/KT-C-KPC-S50NV1-p/kpc-s50nv1.htm
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Re: Minimize effect of IR bults on image
    I would expect that you can turn the LED illumination on and off via remote control.
    fixit7's Avatar
    Jul 2019
    50
    254
    There is no remote.
    Just a basic wired system. (720p B/W)
    Opening the blinds a little helped.
    Points: 17,232, Level: 31
    Nov 2012
    3,148
    17,232
    31
    Re: Minimize effect of IR bulbs on image
    There are IR filters available; make sure that they are IR absorbing. IR transmitting filters are dark but IR absorbing filters are slightly blue. You may have to use two of them stacked together.
    But then your nighttime recording will suffer.
    Full Member level 1
    Points: 2,148, Level: 10
    Nik_2213's Avatar
    Jul 2010
    UK
    98
    2,148
    10
    Faced with a similar situation for two pan/tilt IPCAMs and one 'trad' CCTV, I fitted our patio with an IR mini-floodlight with integral day/night photo-sensor.
    Tough, IP 65, drew 20 Watt, played nice with the cameras by 'filling the shadows' and mitigating their night-lights' back-scatter from nearby objects such as white plant-pots....
    The mini-floodlight cost ~ 35 (~$40), but is now ~ 20. As the 'fly lead' was very, very short, I also needed an adjacent IP65 junction /gland box ~ 5...
    FWIW, mini-floodlight's IR LED array included one (1) far-red LED to show status.
    fixit7's Avatar
    Jul 2019
    50
    254
    Quote Originally Posted by Nik_2213 View Post
    Do you have a link to those?
    Thanks.
  7. #7
    Full Member level 1
    Nik_2213's Avatar
    Jul 2010
    UK
    98
    2,148
    10
    Quote Originally Posted by fixit7 View Post
    Found them on Amazon...
    "IP65 Waterproof Outdoor Security LED Floodlight with Built-in Photocell Sensor 20W "
    "Weatherproof junction box"
    Please use due care with 'mains' wiring, fusing etc. Feed via a 'safety breaker' to be sure, to be sure.
    N
