Results 1 to 12 of 12
    Points: 16,705, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    Difference of S-parameters between Cadence Spectre and Keysight ADSsim
    Calculation method of S-parameters is different between Cadence Spectre and Keysight ADSsim.
    Cadence Spectre evaluates Y-parameters first internally.
    Then it converts Y-parameters to S-parameters using reference impedance values.
    Some simulator has option to choose Y or Z parameters.
    On the other hand, Keysigh ADSsim does not use Y or Z parameters to calculate S-parameters.
    Keysigh ADSsim calculate S-parameters directly by power wave formulation.
    Power wave is defined by voltage, current an reference impedance.
    Assume 2-port DUT where Y-parameters don't exist.
    For example, shunt element.
    Cadence Spectre can not give S-parameters.
    Keysigh ADSsim can give S-parameters.
    Points: 30,243, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,422
    30,243
    42
    Re: Difference of S-parameters between Cadence Spectre and Keysight ADSsim
    I don't think so, otherwise it would be great shame for Cadence.
    Which version of spectre do you use but it computes s-parameters of an shunt inductor.
ID:	154610Click image for larger version.
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    Quote Originally Posted by BigBoss View Post
    How about series element which does not have Z-parameters.
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,422
    30,243
    42
    It's as expected..
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    I don't think so,
    This issue was filed as PCR(Product Change Request)-464911
    "Systems which does not have a valid Y matrix give arithmetic exception"
    Thanks for confirming.
    I also confirmed.
    Now this issue has been fixed in Cadence Spectre.
    "sp_shunt.scs"
    simulator lang=spectre
    global 0
    PORT1 (Vin 0) port r=50 num=1 type=dc mag=1
    PORT2 (Vin 0) port r=50 num=2 type=dc
    Rx (Vin 0) resistor r=50
    //Rx (Vin 0) resistor r=50/2/(sqrt(2)-1)
    heppoko options reltol=1e-5 vabstol=3e-8 iabstol=1e-13 temp=16.85 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
        sensfile="../psf/sens.output" rawfmt=psfascii
    aho noise values=[100M] annotate=status oprobe=PORT2 iprobe=PORT1
    boke sp values=[100M] annotate=status donoise=yes oprobe=PORT2 iprobe=PORT1
    kasu ac values=[100M] annotate=status
    hyottoko options save=allpub
    "boke.sp"
    HEADER
    "PSFversion" "1.00"
    "BINPSF creation time" "1564453319"
    "simulator" "spectre"
    "version" "17.1.0.307.isr6"
    "date" "11:21:59 AM, Tue Jul 30, 2019"
    "design" "(no title)"
    "analysis type" "sp"
    "analysis name" "boke"
    "analysis description" "S-Parameter Analysis `boke': freq = 100 MHz"
    "xVecSorted" "unknown"
    "tolerance.relative" 1.00000e-05
    "mode" "ss"
    "number of ports" 2
    "PORT2:r" 50.0000
    "PORT2:num" 2
    "PORT2:units" "Ohm"
    "PORT1:r" 50.0000
    "PORT1:num" 1
    "PORT1:units" "Ohm"
    TYPE
    "sweep" FLOAT DOUBLE PROP(
    "key" "sweep"
    "S-Param" COMPLEX DOUBLE PROP(
    "key" "SP"
    SWEEP
    "freq" "sweep" PROP(
    "sweep_direction" 0
    "units" "Hz"
    TRACE
    "s22" "S-Param"
    "s12" "S-Param"
    "s21" "S-Param"
    "s11" "S-Param"
    "cy22" "S-Param"
    "cy12" "S-Param"
    "cy21" "S-Param"
    "cy11" "S-Param"
    VALUE
    "freq" 1.00000e+08
    "s22" (-0.333333 0.00000)
    "s12" (0.666667 0.00000)
    "s21" (0.666667 0.00000)
    "s11" (-0.333333 0.00000)
    "cy22" (0.0200000 0.00000)
    "cy12" (0.00000 0.00000)
    "cy21" (0.00000 0.00000)
    "cy11" (0.00000 0.00000)
    END
    Points: 13,942, Level: 28
    Apr 2014
    2,180
    13,942
    28
    That is why it is important to specify software version when discussing such issues. "Now" is not a useful specification.
  7. #7
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    Quote Originally Posted by volker@muehlhaus View Post
    See simulation result.
    You can see version which I use.
    However I don’t know in which version this issue was fixed.
  8. #8
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,422
    30,243
    42
    I'm using Spectre 17.10.627 and it seems working..
    But I personally don't like Spectre in RF simulation.You can even not attribute the frequency on Smith Chart to see impedance/admittance at particular frequency..Since 20 years..
    My favorite one is Keysight GoldenGate. It's marvelous..
  9. #9
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    Right.
    However this is not issue of Cadence Spectre.
    This issue is for Cadence ViVA.
    Simulation performance of current Cadence Spectre is fairly good even for multi-tone HB Analysis.
    http://www.designers-guide.org/Forum...1170364605/2#2
    https://designers-guide.org/forum/Ya...num=1205223090
    https://designers-guide.org/forum/Ya...num=1162921214
    It's marvelous..
    It is very amazing.
    I think no one use Keysight GoldenGate and even Keysight almost abandon promotion of GoldenGate anymore.
    Keysight GoldenGate is almost EOL.
    https://designers-guide.org/forum/Ya...m=1268404959#7
  10. #10
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,422
    30,243
    42
    Quote Originally Posted by pancho_hideboo View Post
    It is very amazing.
    No, Goldengate is still promoted..
    https://www.keysight.com/en/pd-29980...6&cc=US&lc=eng
    This version will be compatible with ADS2020 and IC6.1.8.
  11. #11
    Oct 2006
    Real Homeless
    2,565
    16,705
    31
    There is no thread about Goldengate in this forum.
    There is no reference of Goldengate in foundary document.
    I foresee EOL of Goldengate in near future.
  12. #12
    Apr 2014
    2,180
    13,942
    28
    I often think this forum is most popular among the lazy students, people trying to find someome to solve their homework. There's few power users here .. not exactly the community to discuss advanced EDA stuff.
