Results 1 to 12 of 12
    Junior Member level 1
    Points: 152, Level: 2
    May 2019
    15
    152
    Choose a proper magnetic field sensor
    Hi, i'm designing a smart parking and want to use magnetic field sensor on the ground (under the car) to detect the parking free/busy status.
    I prefer magnetic field sensor because ultrasonic need straight line of sight and cannot work within the box. And infrared sensor have problem in sun light. Other sensors cannot work on the 20-100 Cm distance (If this consideration have fault, please tell me)
    So i need help to choose a proper "chip" for my PCB that have a cheap price.
    Points: 263,617, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,057
    263,617
    100
    Re: Choose a proper magnetic field sensor
    How do you detect car presence with a magnetic field sensor?
    I would suggest a sensor loop as used for traffic light control.
    Banned
    Points: 6,247, Level: 18
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    Try using SPAD LiDaR device, like VL53L0X for your purpose. Depending on what you are envisioning this might work better. Be aware that this too gets limited in bright outdoor direct sunlight.
    Full Member level 6
    Points: 4,745, Level: 16
    Feb 2002
    321
    4,745
    16
    You could try the TI mm wave sensors.
    Points: 80,392, Level: 69
    Apr 2014
    16,308
    80,392
    69
    In my eyes the simplest, with low effort should be an ultrasonic sensor.
    But it's not clear to me why you think it will not work in your case.
    --> please make a draft about your application.
    There are already car detectors in parking houses... how do they work? Can't you use them as proven technique?
    May 2019
    15
    152
    Ultra Sonic cannot work behind a plastic box. So, i need a sensor that be able to detect material: detect metal of car's body and not deceiving with my plastic box.
    and about direct sunlight problem => that is crucial. because my application is on-street
  7. #7
    Apr 2014
    16,308
    80,392
    69
    You don't give much information. You will have your reasons, but it makes it almost impossible to help.
    Regarding IR and sunlight: usually sunlight is cancelled out by modulating the IR source and detecting the modulation signal...
  8. #8
    Points: 53,567, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,068
    53,567
    56
    I was just about to recommend something like an electronic compass made from hall sensors (example, digital compass in automobiles). But hall sensors respond to a magnetic field, and steel cars lack magnetism to influence a hall sensor.
    What kind of compass is in my steel car? By an internet search it appears that a different strategy is used in such compasses. A large ferrous mass alters the response of a hall sensor (or parallel hall sensors, or anti-parallel hall sensors) to the earth's magnetic field. This needs to be subtracted, but for your project it may work as a vehicle detector.
    The article below might have a method you can use to detect a steel vehicle.
    http://www.safety-devices.com/how-do...work-a-12.html
  9. #9
    Points: 18,428, Level: 32
    Nov 2012
    3,267
    18,428
    32
    How about a large area coil using the principles of metal detector? They can have rather longer range and not affected by light etc etc.
  10. #10
    Nov 2012
    3,267
    18,428
    32
    The transducer can be mounted outside the box; it is quite robust. IR sensors are modulated; just like a remote control they can work in outdoor light. Will the magnetic field sensor will work at 100cm?
    Others have already pointed out some of these...
  11. #11
    Points: 95, Level: 1
    Nov 2019
    London
    15
    95
    The Magnetic Field Sensor can be used to study the field around permanent magnets, coils, and electrical devices. You can buy MC910 magnetic field sensor for your parking project.
  12. #12
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,057
    263,617
    100
    MC910 is a low frequency AC magnetic field sensor. Useless for car presence detection.
