Results 1 to 3 of 3
    Points: 402, Level: 4
    May 2018
    42
    402
    $urandom_range is generating same values
    I am writing a test bench where I am randomizing few inputs using $urandom_range(max,min). However, every time I am running my test, it is returning same value. I would like to understand why I am getting this issue.
    Thanks!
    Advanced Member level 3
    Points: 6,466, Level: 19
    Created Blog entry 7 years registered
    Dec 2011
    Fremont, CA, USA
    781
    6,466
    19
    Blog Entries
    Re: $urandom_range is generating same values
    That is the correct behavior - it's called random stability which allows you to debug your test should it fail. You need to change the initial seed if you want another set of random values. Using Modelsim/Questa, look up the vsim -sv_seed switch in the manual
    Dave Rich
    Senior Verification Consultant
    Mentor Graphics Corporation
    May 2018
    42
    402
    Quote Originally Posted by dave_59 View Post
    Thank you for detailed explanation. This makes sense to me. I was able to use -seed random in Cadence xrun to get desired behavior.
    Thanks!
