LDO Simulation - Cadence - ILoad vs. Vout - Line Regulation
Puppet123
Full Member level 6
I would like to plot Iload vs. Vout for the Line Regulation for an LDO in Cadence Virtuoso and am wondering what the best approach would be.
I can put just an ideal current source, Idc using AnalogLib as the Load but that doesnt seem correct.
Should I use a controlled source in Cadence instead, like a current or voltage controlled source that links the two - if so - how would that be set up ?
Thank you.
Why ?? Ideal Current Source with Idc Parametric Value that varies during DC Simulation will give you I_Load vs. V_Out..
