Simulation problem with MMSIM using smic 65nm technology
abdoboua
Junior Member level 1
Hello, I have a problem when simulating an inverter created with smic 65nm technology library.
Here is a screenshot for the error messages
Also I don't know what model files to choose, Is it .ckt files or .mdl files
and in the simulator_version.txt file it mentions that it should be Cadence spectre version -------- V6.2.1 or newer. and I am working with MMSIM15.10.257
Your help appreciated
Simply the simulator does not know which model you have used.
Model files must be defined in "Setup" tab in ADE.
I don't know which files to choose ,either .mdl or .ckt
