Results 1 to 9 of 9
    Advanced Member level 2
    Points: 4,214, Level: 15
    Jun 2012
    Chennai
    656
    4,214
    15
    Low drop voltage regulator
    I'm designing a battery operated circuit where the load current will be max. 50mA.
    Can I use LP2950-3.3V or MIC5236-3.3V?. Which is better. Or do you suggest other IC.
    Thanks in advance.
    Full Member level 6
    Points: 2,003, Level: 10
    Jan 2019
    373
    2,003
    10
    Re: Low drop voltage regulator
    looks like either will be ok
    TI and Micrel are reliable manufacturers.
    what voltage will you be providing to the regulator?
    what is the maximum current at turn on or turn off?
    if its battery operated, why are you using a regulator?
    i suggest a 1 uF cap on the input voltage and on the output voltage
    (unless the data sheet specifically says otherwise)
    Points: 77,645, Level: 67
    Apr 2014
    15,729
    77,645
    67
    Which is better.
    "Better" in which regard?
    Beauty? Long legs?
    Points: 3,760, Level: 14
    May 2012
    504
    3,760
    14
    What about the AMS1117 3.3V ? I as well as many others sell them on eBay for not much money. As wwfeklman said it is important to use the manufacturer’s recommendations as to the input and output capacitors.
    Points: 17,223, Level: 31
    Nov 2012
    3,147
    17,223
    31
    It will be useful to remember that they are basically linear regulators and waste energy- that may be some consideration for battery operated devices.
    Use the regulator only for the part that demands regulated voltage. There are lots of low drop regulators in the market.
    Points: 14,929, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,480
    14,929
    29
    You should have included the datasheets in your message such that people here could perform a quick analysis and comparison of parameters.
    The only other parameter I would consider what is the variation the regulator's ground pin current vs load. More so near the dropout threshold.
    I have used the LP295x regulator extensively for many years, and can tell you that it is not very good in that respect.
    My batteries are recharged by "Helpful Post" ratings.
  7. #7
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,436
    260,175
    100
    You didn't specify relevant application parameters except 50 mA current. How about the input voltage, expected quiescent current? AMS1117 has >1 V dropout voltage, no true LDO.
  8. #8
    May 2012
    504
    3,760
    14
    The AMS1117 has a dropout of 1.1V at 0.8A, at 50mA the dropout is much less.
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,436
    260,175
    100
    About 0.7 V at low currents, if you call it LDO, I won't.
    Also quiescent current isn't mind blowing. Again, if we know the requirements, we can suggest an appropriate regulator type.
