Results 1 to 9 of 9
    Points: 32,579, Level: 44
    Sep 2008
    cambridge
    6,785
    32,579
    44
    Circuit to pulse from 1v to 1.1v repeatedly.
    Hi ,
    We need the “Output”of the following circuit to go from 1v to 1.1v as shown in the LTspice simulation. We are worried we may get too much VCE drop in the pnp….the datasheet does not tell the vce drop for our conditions, but can you agree that our Vce will be less than 10mV when ON?
    2N3906
    https://www.onsemi.com/pub/Collateral/2N3906-D.PDF
    Points: 77,038, Level: 67
    Apr 2014
    15,608
    77,038
    67
    Re: Circuit to pulse from 1v to 1.1v repeatedly.
    Why no Mosfet?
    Sep 2008
    cambridge
    6,785
    32,579
    44
    Thanks......it would need to be pfet, and i cant pull the gate down far enough as its only a 1.1v rail.
    (admittedly we could make a negative rail for this purpose but its extra components)
    Points: 80,963, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,270
    80,963
    69
    Wouldn't it be more sensible to switch the voltage at the input of the op-amp where the current is small and independent of load. You can set the voltage with resistors, use the op-amp output directly and avoid the transistors altogether.
    Points: 259,210, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,250
    259,210
    100
    Not sure, at least several mV.
    To implement a BJT analog switch with zero offset voltage, operate the transistor inversely. Disadvantage is current gain of about unity.
    Advanced Member level 3
    Points: 5,544, Level: 17
    Feb 2014
    787
    5,544
    17
    Agree: just switch or mux the opamp reference.
    A second option is to mux two different sources. NLASB3157 is an example of SPDT analog mux.
  7. #7
    Points: 52,606, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,876
    52,606
    56
    From a 1V supply the astable multivibrator produces 1.35V peaks at the capacitors.
    I'm not sure if this can be adapted to your purposes but the topic appears to ask for a simple method to get slightly higher voltage from a 1V source.
Name:	astable multivibrator 2 PNP peaks 1_35 V from 1V supply.png
    My schematic has PNP type. The usual schematic has NPN type and so it produces negative polarity at the capacitors.
  8. #8
    Points: 10,713, Level: 24
    Aug 2015
    1,734
    10,713
    24
    from the graphs in the data sheet - the best you can do with this device is about 80mV for 1mA collector and 100uA base, there are a heap better pnp's for this, usually 1 amp from zetex ...
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,250
    259,210
    100
    Circuit load current wasn't yet specified. Even low Vcesat transistors (e.g. NXP "BISS" types) have Vcesat almost converging against a constant value at low Ic values. Vcesat is caused by forward biased BC diode and it's voltage characteristic related to BE diode.
    As previously mentioned, you get < 1mV Vcesat in inversed operation, no idea if it helps for your application.
