Results 1 to 5 of 5
    Points: 32,326, Level: 43
    Sep 2008
    cambridge
    6,734
    32,326
    43
    Linear led current regulator
    We are seeking a linear led current regulator. We need it to be an error amplifier on a chip……..but the drive fet will be external, and the reference to the internal error amplifier will be input from an external source. We cant find anything offtheshelf…and digikey etc don’t allow us to sort on our requirements….does anyone know of anything?
    The current sense resistor will also be external.
    Advanced Member level 3
    Points: 5,484, Level: 17
    Feb 2014
    778
    5,484
    17
    Re: Linear led current regulator
    Sounds like you need this chip called an 'op-amp'....
    I mean what value-add do you want from the chip? You buy LED drivers because they provide all the things you specified are external.
    EDIT: Though I suppose by reference you just meant the current set point and you're looking for all the pwming and blinking? In that case I suspect you'll have to live with a chip that provides something you don't need. If it has internal low-side current regulators for example so be it, open load they'll be like open drain outputs.
    Points: 6,247, Level: 18
    kripacharya's Avatar
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    Quote Originally Posted by asdf44 View Post
    Sounds like you need this chip called an 'op-amp'.....
    good call !
    Alternatively just use an Lm317 current source config. But then the max current is limited.
    Points: 76,224, Level: 67
    Apr 2014
    15,457
    76,224
    67
    ...and where are your requirements?
    Voltage, LED current range, input signal type and range, precision, settling time...
    Points: 19,467, Level: 33
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Dec 2010
    Tehran - IRAN
    3,984
    19,467
    33
    Blog Entries
    8
    Hi
    As i know , you can go through LT (Linear technology productions ) chips . I used many led drivers and current controller chips from that company .
    However it would be nice if you could at least give us more specifications . Isn't it ?
    Best wishes
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
