Results 1 to 8 of 8
    Points: 668, Level: 5
    Feb 2017
    40
    668
    What is the difference between IRF510 and IRF510N?
    Is N MOSFET IRF510 the same as IRF510N?
    If not what is difference?
    Points: 23,830, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,571
    23,830
    37
    Re: What is the difference between IRF510 and IRF510N?
    Infineon (who now owns IR) doesn’t even list the 510N. Maybe it’s a counterfeit part. I’d just try it.
    Feb 2017
    40
    668
    Maybe.
    On the other side when you make counterfei why would you change the name?
    IRF510N are commonly found, for example
    Points: 76,403, Level: 67
    Apr 2014
    15,499
    76,403
    67
    You buy a "unbranded" electronic device, made in china, from an unreliable source, without datasheet.
    So what do you expect from us?
    All we can do is give "equal unreliable" informations.
    Maybe one user tells you his experience is that it is equal to the original part, because it has identical R_ds_on.
    Maybe another user tells you that it is not equal because it has different Coss.
    --> You can never be sure.
    In the end only you will be responsible for what parts you use.
    Points: 258,568, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,148
    258,568
    100
    IRF510 has been discontinued by IRF/Infineon since many years but is still stocked at catalog distributors. I never saw an IRF510N type made by IRF. Can you show me a datasheet or official catalog?
    Other N postfix types have be made by IRF or are still made by Infineon.
    Apparently all from Chinese sources. If they prove good for your purposes, don't worry about N postfix.
    Full Member level 5
    Points: 2,576, Level: 11
    Jul 2012
    278
    2,576
    11
    it is a little different.
    IRF510 not a prinary only product of IR, but De facto industry standard manufactured in many campny , today for example IRF510 make Vishay
    and IRF510N was partnumber for this transistor in Motorola Solution Inc. see her
  7. #7
    barry's Avatar
    Mar 2005
    California, USA
    4,571
    23,830
    37
    Motorola became Onsemi, and THEY don’t list an IRF510N EITHER. If you follow the link on datasheet360 to the alleged IRF510N, there’s no such part listed.
  8. #8
    Member level 5
    Points: 881, Level: 6
    Dr_Mohammad's Avatar
    Nov 2016
    Khorramabad, Iran
    90
    881
    Quote Originally Posted by Jadeit View Post
    both are N-Channel 5.6A 100V.
    Hope is a good thing, maybe the best of things and no good thing ever dies (The Shawshank Redemption).
