Results 1 to 10 of 10
    Full Member level 1
    Points: 2,145, Level: 10
    May 2010
    fdsf
    118
    2,145
    10
    I cannot power that pelletier module : TEC2-25408
    I have tried to power that pelletier module with an AT power supply but I reached max -10°C or something
    so I ordered a 12V 10A power supply,
    as I measure the pelletier module, it really does not go up to specs
    barely -20°C (should <-30°C) and current is only half of the specified current
    pelletier:
    https://www.aliexpress.com/item/3238...662f6f04RWvMLA
    power supply:
    https://www.aliexpress.com/item/3299...3da24c4d7hBp9i
    fan: I am using a 12V fan with a 10x10x4cm CPU fan
    what am I missing ?
    sheers
    Points: 258,478, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,123
    258,478
    100
    Re: I cannot power that pelletier module
    Do you have a full datasheet with I/V/ΔT curves? What's the expected hot side temperature for -30° cold side? Did you check the actual temperature?
    Most likely problem is insufficient heat sinking at the hot side.
    Full Member level 1
    May 2010
    fdsf
    118
    2,145
    10
    yes, checked the temp with an ir temp "gun"
    I am indeed building a bigger cooler/double fan apartus
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,123
    258,478
    100
    It's generally no good idea to operate a peltier element with fixed voltage supply because for each combination of heat sink thermal resistance, ambient temperature and pumped power there's an optimal operation current respectively voltage.
    Said TEC2-25408 may need higher voltage, e.g. 14 or 15 V.
    Full Member level 1
    May 2010
    fdsf
    118
    2,145
    10
    I can try many different voltages
    yet, finding datasheets is not easy
    Points: 9,923, Level: 23
    Aug 2015
    1,620
    9,923
    23
    please describe your heat-sinking - if any ...?
  7. #7
    Points: 14,656, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,436
    14,656
    29
    After all is done and said, this is a thermodynamic problem.
    -What is the fan’s airflow and under what static pressure?
    -What is the heatsink’s thermal resistance, with the calculated airflow?
    -What is the heatsink’s ambient temperature?
    -How many calories, joules, BTUs (or whatever thermal unit you wish to use) is the peltier module rated for? How does that compare to your thermal load?
    -What are the peltier’s losses, which the heatsink will also dissipate?
    My batteries are recharged by "Helpful Post" ratings.
  8. #8
    Full Member level 1
    May 2010
    fdsf
    118
    2,145
    10
    no idea... just trying to follow this tutorial : https://www.instructables.com/id/Pel...Cloud-Chamber/
    I'll purchase a piped cooler like the one he uses, this gotta work
  9. #9
    Aug 2015
    1,620
    9,923
    23
    without calculating the heatsinks required for each side and the watts you are ( hopefully ) shifting off the hot side - you are operating blind - very tricky to arrive at a useful working arrangement under this approach ...
  10. #10
    Advanced Member level 2
    Points: 5,009, Level: 16
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    593
    5,009
    16
    Watch this channel on YT, you will find lot of interresting things about peltiers.
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
