Results 1 to 2 of 2
    Newbie level 1
    Points: 14, Level: 1
    Jul 2019
    14
    Coupled nets from parasitics spef file
    What are the possible cases of an D_NET being coupled to another net.
    One case is that it is directly under the CAP section of the D_NET like:
    D_NET a <whatever_value>
    *CONN
    CAP
    1 a b:1 <whatever_value>
    2 a c:2 <whatever_value>
    In above skeleton case, D_NET 'a' would be coupled to nets b and c.
    I am sure that there are other cases from where D_NET 'a' could be coupled to.
    What are those cases? If D_NET 'b'(other than the one in skeleton) is coupled with D_NET 'a', then does it mean that 'a' is also coupled to 'b'? Basically, I wanted to know if there are any cases like that.
    Thanks.
    Points: 8,440, Level: 21
    Apr 2016
    1,772
    8,440
    21
    Re: Coupled nets from parasitics spef file
    I am not sure I understand the question. If you are asking if C is counted twice, the answer is yes. You have A->B and B->A listed as being separate capacitances with the same value.
    Really, I am not Sam.
