Results 1 to 5 of 5
    Full Member level 3
    Points: 2,700, Level: 12
    Jul 2009
    Portugal
    161
    2,700
    12
    NodeMCU ESP-32S pitch
    Hello!
    I have several ESP-32S NodeMCU boards. I'm going to design a PCB board to connect to it by SIL header blocks. These boards have a pitch of 2,54mm? And the distance from side header pins is 25,4mm? This dimensions are standard for the reference of this board?
    I have tried to find a PCB footprint of the board but did not find any.
    Thanks,
    Bruno
    Points: 29,544, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,815
    29,544
    41
    Blog Entries
    9
    Re: NodeMCU ESP-32S pitch
    If you have these boards in hands, why not you measure them? By the way, at least with the ESP32 relative, the ESP8266, there are a number of NodeMCU's variants from many manufacturers, therefore in order to avoid mistake from someone which has another brand, I would suggest you share here a picture of the board that you got, if you do not have paquimeter or are not comfortable to scan coordinates of the pins with a ruler.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 76,224, Level: 67
    Apr 2014
    15,458
    76,224
    67
    There are datasheets... telling you the measures.
    Points: 80,492, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,191
    80,492
    69
    ...but most ESP32 modules are 1.27mm pitch. Half of standard 0.1 inch spacing.
    If the module is on a board with USB interface and PSU, it is normally 2.54mm but width across sides varies form one manufacturer to another.
    Full Member level 3
    Jul 2009
    Portugal
    161
    2,700
    12
    Hello!
    Thanks for the inputs! I have attached the photos of the board. Today, I could measure it with a paquimeter and it has 23mm between the two pin headers and 2,54mm pitch:
    I have boards from different suppliers and I thought that it would be standard these two measures, but I'm afraid not since it varies between them.
    Thanks,
    Bruno
