Results 1 to 7 of 7
    Newbie level 1
    Points: 131, Level: 1
    Jun 2019
    Erina NSW
    7
    131
    Lenovo laptop problem during installing LINUX OS
    Hi, I'm using Lenovo, when I try to install Linux my laptop got stuck after I switched it off and on. it's not working, all lights up but the screen is blank, CPU fan is running 3 sec only, can anyone help me with this, please.
    Points: 53,470, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,055
    53,470
    56
    Re: Lenovo laptop problem during installing LINUX OS
    I once installed Linux on my Compaq laptop (to a re-formatted hd). Things worked to the point where I saw the desktop open and appeared normal. However it froze when I tried to open any application. I had to fall back to Win XP.
    Message boards spoke of needing correct Linux drivers for all devices in a computer. I took that to be a plausible explanation for my lack of success. However I didn't see a way to add drivers to the install CD after burning the ISO file.
    Your installation might work if you can figure out what drivers you need, and add them during the install process.
    Member level 4
    Points: 866, Level: 6
    Jun 2017
    near the sea
    68
    866
    Quote Originally Posted by victorjohn9211 View Post
    What Distro exactly are you using and what is the media, what is the model of laptop, how much memory, what sort of storage etc etc!!
    Points: 82,575, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,555
    82,575
    70
    Agreed - lots more information needed. I have only once seen this happen and it was due to a UEFI 'lock' in the BIOS that prevented anything but Windows being installed. It took some defeating but I got it working in the end. If the BIOS has a setting to use legacy mode rather than UEFI it would be a good place to start looking. All modern Linux versions are UEFI aware and quite happy to use it but some hardware manufacturers have agreements with MS to prevent other OS being installed easily so they deliberately block the boot process even though the installation appears to have worked.
    Junior Member level 1
    Points: 95, Level: 1
    Nov 2019
    London
    15
    95
    You should check your laptop configuration.
    Points: 18,428, Level: 32
    Nov 2012
    3,267
    18,428
    32
    Modern linux is quite robust: did your installation went through all right?
    Please mention the specific distribution of Linux you are using. Those forums can provide more fine grained response.
  7. #7
    Points: 40,467, Level: 49
    Mar 2008
    USA
    6,528
    40,467
    49
    Some distros are much more helpful / forgiving than others.
    Ubuntu worked out pretty well for me, on a Dell which has
    a near-orphan GPU. Red Hat / CentOS, I could never get
    the display right on.
    Seems like the "easy" installs want to set you up with the
    desktop / GUI interface on boot. That's not going to work
    out well if you don't have (that is, the distro doesn't) a
    good handle on the hardware. If you are looking at a
    custom or just don't-have-drivers situation, setting up
    for a console mode, enter-GUI-by-command old school
    Linux environment may be a better bet. This option may
    take some figuring out, I haven't seen it presented as
    an option lately myself.
