Results 1 to 7 of 7
    Newbie level 1
    Points: 39, Level: 1
    Jul 2019
    39
    LM741 Amplifier not working with IR2110 IC [PROTUES]
    Im trying to amplify arduino output for Mosfet gate driver, but whenever I connect to Output terminal to amplifier the HI pin doesnot accept amplifier output idk why. But when I connect arduino directly with the HI pin, the small flash light about it blinks and it shows output too. Also when I connect amplifier with a voltmeter, its shows the input is amplified but it doesnt work with HI pin when i connect to it.Please help me determine the issue here. Circuit shown below.
    Points: 29,635, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,863
    29,635
    41
    Blog Entries
    9
    Re: LM741 Amplifier not working with IR2110 IC [PROTUES]
    With the above value at VDD of IR2110, the HIN pin allows input varying from approximately 0v to 12v, but the 741 has differential supplies ranging from -10v to +10v.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 39,705, Level: 48
    Mar 2008
    USA
    6,413
    39,705
    48
    I think you'd be much better off with a simple level-shifter
    logic gate (believe IR2110 accepts standard 5V "TTL" inputs).
    Op amp like 741 will have very slow output slew rate and
    there might be some issues with that. Driving a "100nS"
    part with a "10uS" risetime is asking for trouble especially
    when you have close-coupled, high dV/dt, high dI/dt
    goings-on. Although Schmitt inputs are depicted, there
    is no mention of attributes (hysteresis, or min input dV/dt
    or max risetime).
    Points: 77,782, Level: 68
    Apr 2014
    15,759
    77,782
    68
    The arduino output is "digital", and so is the IR2110 input.
    But the Opamp is an "analog" circuit.
    Don't mix analog and digital this way.
    The circuit simply is not suitable.
    Why do you try to re invent the wheel (while you don't have the knowledge for it ) ... why don't you use one of the thousands (or millions) proven circuits you can find here in the forum and in the internet?
    The most reliable informations with a lot of explanations ( in datasheets, application notes) you will find at the semiconductor manufacturers.
    For example they tell you what capacitors and diodes to use (and why not to use electrolytics capacitors and 1N4007)
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    The design fault is to connect VDD to 12V, with 5V supply, the IR2110 logic inputs can be driven by processor signals directly.
    Member level 3
    Points: 1,989, Level: 10
    May 2010
    Coimbatore, Tamil Nadu, India
    65
    1,989
    10
    what is the maximum duty cycle of the drive signal from arduino?
    first you have to turn on the low side MOSFET in order allow the bootstrap capacitor to charge and then only it will work properly.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Something between 95 and 99%. There's no big advantage of increasing it above 95%.
