Results 1 to 4 of 4
    Points: 999, Level: 7
    May 2014
    9
    999
    7
    Problem with my echo circuit using PT2399
    I'm using PT2399 IC for my echo circuit as shown in the application circuit. The circuit is working fine alone. But I'm using a mixer to feed the input. I'm using my yamaha mixer's auxillary output to feed the input of echo circuit and the output of echo circuit is fed to another channel (say echo channel), the mic is plugged into another channel of the mixer. When the fader of the echo channel is increased, the clarity of the mic output is decreasing and the sound gets dampened. It sounds as if the bass is decreasing and the sound is getting flat. I don't understand what the problem is. Please help me.
    Points: 24,065, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,616
    24,065
    37
    Re: Problem with my echo circuit using PT2399
    It’s not really clear from your description what you’re doing, but my guess is that you have a phasing issue. For example, when you’ve got stereo speakers hooked up “out of phase”, in other words, you’ve got the positive of one channel going to the negative input of the speaker, you’ll get bass cancellation, since the speaker cones are moving in opposite directions for a given signal.
    Points: 77,106, Level: 67
    Apr 2014
    15,621
    77,106
    67
    My idea:
    The echo is inverted (for low frequencies).
    Points: 259,331, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,280
    259,331
    100
    The standard PT2399 application circuit is sending the low-pass filtered original signal to the output, that's not appropriate for an echo effect connected to the effect send and return of a mixing console.
    You better connect the delayed signal only (red) to the effect return. The low pass filter may still affect the sound quality.
